My 2DOF Kit Build
Discussion in 'DIY Motion Simulator Projects' started by Paul Shortland, May 15, 2015.
  1. noorbeast
    153,764Coins
    +11,149 / 57 / -2
  2. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Ah yes that's it, I don't have a licence right now. Time for some paperwork!
  3. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Got my licence, yay!
    Having a, what have I not done, moment.
    I have the arduino code from @Wanegain (below) and I have set up simtools (i think).
    Tools.jpg Could anyone take a look at the details and let me know what else? Do I need do something with describe? Sim is unresponsive but powers up ok so I think it's software related.
    Arduino...
    Changelog : 1.23 : Now when the simulator receives the stop frame it returns to starting position (512)
    10 bits (16 bits value / 64)
    XL~a01~CXR~a02~C
    XL<Axis1>CXR<Axis2>C
    XE00C - End
    Pin out of arduino for Sabertooth
    Pin 8 - TX data to connect to S1
    Analog Pins
    Pin A0 - input of feedback positioning from motor 1
    Pin A1 - input of feedback positioning from motor 2
    As well 5v and GND pins tapped in to feed feedback pots too.
    #include <SabertoothSimplified.h>
    #include <SoftwareSerial.h>
    //Some speed test switches for testers ;)
    #define FASTADC 1 //Hack to speed up the arduino analogue read function, comment out with // to disable this hack
    // defines for setting and clearing register bits
    #ifndef cbi
    #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
    #endif
    #ifndef sbi
    #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
    #endif
    #define LOWBYTE(v) ((unsigned char) (v)) //Read
    #define HIGHBYTE(v) ((unsigned char) (((unsigned int) (v)) >> 8))
    #define BYTELOW(v) (*(((unsigned char *) (&v) + 1))) //Write
    #define BYTEHIGH(v) (*((unsigned char *) (&v)))
    #define GUARD_MOTOR_1_GAIN 100.0
    #define GUARD_MOTOR_2_GAIN 100.0
    int DeadZone = 5; //increase this value to reduce vibrations of motors
    int ReadAnalog = 8;
    int currentanalogue1 = 0;
    int currentanalogue2 = 0;
    int target1=512;
    int target2=512;
    int buffer=0;
    int buffercount=-1;
    int commandbuffer[5]={0};
    // Pot feedback inputs
    int FeedbackPin1 = A0; // select the input pin for the potentiometer 1, PC0
    int FeedbackPin2 = A1; // select the input pin for the potentiometer 2, PC1
    //180°
    int FeedbackMax1 = 962; // Maximum position of pot 1 to scale, do not use 1023 because it cannot control outside the pot range
    int FeedbackMin1 = 62; // Minimum position of pot 1 to scale, do not use 0 because it cannot control outside the pot range
    int FeedbackMax2 = 962; // Maximum position of pot 2 to scale, do not use 1023 because it cannot control outside the pot range
    int FeedbackMin2 = 62; // Minimum position of pot 2 to scale, do not use 0 because it cannot control outside the pot range
    //150°
    int FeedbackMax1 = 888; // Maximum position of pot 1 to scale, do not use 1023 because it cannot control outside the pot range
    int FeedbackMin1 = 136; // Minimum position of pot 1 to scale, do not use 0 because it cannot control outside the pot range
    int FeedbackMax2 = 888; // Maximum position of pot 2 to scale, do not use 1023 because it cannot control outside the pot range
    int FeedbackMin2 = 136; // Minimum position of pot 2 to scale, do not use 0 because it cannot control outside the pot range
    int FeedbackPotDeadZone1 = 0; // +/- of this value will not move the motor
    int FeedbackPotDeadZone2 = 0; // +/- of this value will not move the motor
    //PID variables
    int motordirection1 = 0; // motor 1 move direction 0=brake, 1=forward, 2=reverse
    int motordirection2 = 0; // motor 2 move direction 0=brake, 1=forward, 2=reverse
    int oldmotordirection1 = 0;
    int oldmotordirection2 = 0;
    double K_motor_1 = 1;
    double proportional1 = 4.200; //initial value
    double integral1 = 0.400;
    double derivative1 = 0.400;
    double K_motor_2 = 1;
    double proportional2 = 4.200;
    double integral2 = 0.400;
    double derivative2 = 0.400;
    int OutputM1 = 0;
    int OutputM2 = 0;
    double integrated_motor_1_error = 0;
    double integrated_motor_2_error = 0;
    float last_motor_1_error = 0;
    float last_motor_2_error = 0;
    int disable = 1; //Motor stop flag
    //Variables pour la liaison serie de la sabertooth
    int PowerM1 = 0; //puissance moteur 1 [-127 127]
    int PowerM2 = 0; //puissance moteur 2 [-127 127]
    SoftwareSerial SWSerial(NOT_A_PIN, 8); //Pin 8 utilisé pour communiquer avec la Sabertooth
    SabertoothSimplified ST(SWSerial); //nom de l'objet communication serie avec une pin differente de TX
    void setup()
    Serial.begin(9600);
    SWSerial.begin(38400); //boutons 2, 4 et 5 OFF
    ST.motor(1, 0);
    ST.motor(2, 0);
    ST.stop();
    disable=1;
    #if FASTADC
    // set analogue prescale to 16
    sbi(ADCSRA,ADPS2) ;
    cbi(ADCSRA,ADPS1) ;
    cbi(ADCSRA,ADPS0) ;[​IMG]
    #endif
    void FeedbackPotWorker()
    for(int z=0;z<ReadAnalog;z++)
    currentanalogue1 += analogRead(FeedbackPin1);
    currentanalogue2 += analogRead(FeedbackPin2);
    currentanalogue1 /= ReadAnalog;
    currentanalogue2 /= ReadAnalog;
    void SerialWorker()
    while(Serial.available())
    if(buffercount==-1)
    buffer = Serial.read();
    if(buffer != 'X'){buffercount=-1;}else{buffercount=0;}
    else
    commandbuffer[buffercount]=buffer;
    buffercount++;
    if(buffercount > 3)
    if(commandbuffer[3]=='C'){ParseCommand();}
    buffercount=-1;
    void ParseCommand()
    if(commandbuffer[0]=='L') //Set motor 1 position to High and Low value 0 to 1023
    target1=(commandbuffer[1]*256)+commandbuffer[2];
    target1=map(target1,0,1023,FeedbackMin1,FeedbackMax1);
    disable=0;
    return;
    if(commandbuffer[0]=='R') //Set motor 2 position to High and Low value 0 to 1023
    target2=(commandbuffer[1]*256)+commandbuffer[2];
    target2=map(target2,0,1023,FeedbackMin2,FeedbackMax2);
    disable=0;
    return;
    if(commandbuffer[0]=='E') //Disable power on both motor
    unsigned long start;
    unsigned long time;
    start=millis();
    target1=512;
    target2=512;
    time = millis();
    while(time < (start + 3000)) //3s
    FeedbackPotWorker();
    CalculatePID();
    CalculateMotorDirection();
    SetPWM();
    time=millis();
    ST.motor(1, 0);
    ST.motor(2, 0);
    ST.stop();
    disable=1;
    return;
    void CalculateMotorDirection()
    if(target1 > (currentanalogue1 + (DeadZone + FeedbackPotDeadZone1)) || target1 < (currentanalogue1 - (DeadZone + FeedbackPotDeadZone1)))
    if (OutputM1 >= 0)
    motordirection1=1; // drive motor 1 forward
    else
    motordirection1=2; // drive motor 1 backward
    OutputM1 = abs(OutputM1);
    else
    motordirection1=0;
    if(target2 > (currentanalogue2 + DeadZone + FeedbackPotDeadZone2) || target2 < (currentanalogue2 - (DeadZone + FeedbackPotDeadZone2)))
    if (OutputM2 >= 0)
    motordirection2=1; // drive motor 2 forward
    else
    motordirection2=2; // drive motor 2 backward
    OutputM2 = abs(OutputM2);
    else
    motordirection2=0;
    OutputM1 = constrain(OutputM1, -255, 255);
    OutputM2 = constrain(OutputM2, -255, 255);
    int updateMotor1Pid(int targetPosition, int currentPosition)
    float error = (float)targetPosition - (float)currentPosition;
    float pTerm_motor_R = proportional1 * error;
    integrated_motor_1_error += error;
    float iTerm_motor_R = integral1 * constrain(integrated_motor_1_error, -GUARD_MOTOR_1_GAIN, GUARD_MOTOR_1_GAIN);
    float dTerm_motor_R = derivative1 * (error - last_motor_1_error);
    last_motor_1_error = error;
    return constrain(K_motor_1*(pTerm_motor_R + iTerm_motor_R + dTerm_motor_R), -255, 255);
    int updateMotor2Pid(int targetPosition, int currentPosition)
    float pTerm_motor_L = proportional2 * error;
    integrated_motor_2_error += error;
    float iTerm_motor_L = integral2 * constrain(integrated_motor_2_error, -GUARD_MOTOR_2_GAIN, GUARD_MOTOR_2_GAIN);
    float dTerm_motor_L = derivative2 * (error - last_motor_2_error);
    last_motor_2_error = error;
    return constrain(K_motor_2*(pTerm_motor_L + iTerm_motor_L + dTerm_motor_L), -255, 255);
    void CalculatePID()
    OutputM1=updateMotor1Pid(target1,currentanalogue1);
    OutputM2=updateMotor2Pid(target2,currentanalogue2);
    void SetPWM()
    //Set hardware pwm
    //Motor 1
    if(motordirection1 != 0)
    //on fait la conversion en cas positif pour PowerM1 (0 à 127)
    if (motordirection1 == 1) //forward
    PowerM1 = int(OutputM1/2);
    //on fait la conversion en cas negatif pour PowerM1 (-127 à 0)
    else //reverse
    PowerM1 = -int(OutputM1/2);
    ST.motor(1, PowerM1);
    else //motor1 must stop
    ST.motor(1, 0);
    //Motor 2
    if(motordirection2 != 0)
    if (motordirection2 == 1) //sens positif
    PowerM2 = int(OutputM2/2);
    else
    PowerM2 = -int(OutputM2/2);
    ST.motor(2, PowerM2);
    else //motor2 must stop
    ST.motor(2, 0);
    void loop()
    //Program loop
    while (1==1) //Important hack: Use this own real time loop code without arduino framework delays
    SerialWorker();
    CalculatePID();
    if(disable==0)
    SetPWM();
  4. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Hello to all Arduino programmers
    Sorry to dig up old post from March 23, 2019,
    In this code snippet is
    "target1=(commandbuffer[1]*256)+commandbuffer[2];"
    "target1" is in 16 bits?
    In the second line is it a 16-bit to 12-bit transformation?
    If I replace 1023 with 4095 in the second line of "map" code...
    With "target1=map(target1,0,4095,FeedbackMin1,FeedbackMax1);" I think I get "target1" in 12 bits.
    Can you confirm it for me?
    These 2 lines are extracted from this code
    Code:
    void ParseCommand()
     disable=0;
     return;
     disable=0;
     return;
     unsigned long time;
     start=millis();
     target1=512;
     target2=512;
     time = millis();
     CalculatePID();
     SetPWM();
     time=millis();
     ST.motor(1, 0);
     ST.motor(2, 0);
     ST.stop();
     disable=1;
     return;
    Texte original en Français
    Bonjour à tous les programmateurs Arduino
    Désolé de déterrer ancien post du 23 mars 2019,
    Dans cet extrait de code est ce que
    "target1"est en 16 bits ?
    Dans la seconde ligne Est-ce bien une transformation de 16 bits en 12bits ?
    Si je remplace 1023 par 4095 dans la seconde ligne de code "map"
    Avec "target1=map(target1,0,4095,FeedbackMin1,FeedbackMax1);" je pense obtenir "target1" en 12 bits.
    Pouvez vous me le confirmer ?
