Lesson My 2DOF project
Discussion in 'DIY Motion Simulator Projects' started by thanh tin, Aug 25, 2020.
  1. thanh tin
    thanh tin New Member
    173Coins
    I ran a model test in the LFS game when there was no one in the chair. The model still moves normally, but the speed in LFS is too high How do I test a model in Euro Truck Simulation 2 because the game speed is slower than LFS
    154,642Coins
    +11,190 / 57 / -2
    An unloaded test is not going to tell you very much, irrespective of speed.
    Using higher Tuning Center values will result in smoother movement over a larger range of movement.
    Lowering the Intensity Level in the Profile Editor of Game Manager will apply global smoothing to motion.
  3. thanh tin
    173Coins
    thank noorbeast
  4. thanh tin
    173Coins
    Model results with the help of noorbeast You helped me a lot of finishing up the model
