My 2DOF wipe motors and ITEM structure
Discussion in 'DIY Motion Simulator Projects' started by Chumet1, Dec 20, 2014.
  1. Nick Moxley
    17,057Coins
    Ah, Good point, Im neither lol.
  2. bsft
    Depends what his numbers are in the tuning centre, if its a high number, he needs a high percentage
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    There is something not clear to me in this very interesting discussion...
    If I set 20% to a Force, I need to lower the value in Tuning Center (to compare with my current setup). But if I lower the Min/Max value, the data received will be often above this value, right ?
    So can you explain me please the difference between :
    In tuning center Max = 10, in Axis Assignments Force = 100%
    In tuning center Max = 5, in Axis Assignments Force = 50%
    In tuning center Max = 2, in Axis Assignments Force = 20%
  4. Nick Moxley
    17,057Coins
    you are correct in the fact the Tuning center #'s will go beyond the Min/max you have set, but the fact remains that using the actual #'s from a "learn the min/max" wont give you a proper profile really.
    For example, A F1 car will have Heave spikes upwards of 5-10 on the tuning center but will feel like JUNK if you set it for the MAX you see. 1.5-2 for heave is a good start (for Assetto mainly)
  5. Wanegain
    Bruxelles
    2,018Coins
    Thank you for your answer @Nick Moxley.
    If I set for example heave at -2/2 in Tuning Center and 20% in Axis assignments for this force, does it mean that I only use 20% of the range of movement of my Axis for this force (and in this case -2/2 is considered as 100%) or that I need 5*-2/2 to get the full range of movement of my Axis ??
    I need to do some tests I guess...
  6. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I had no idea one could assign more than one DOF to each motor. I tried some of the suggestions on my Arduino Servo model and it came alive!
  7. Nick Moxley
    17,057Coins
    Pitch, Roll, Heave, Sway, Surge , And TL when you have it.
    Dont go crazy on the axis %, Its a balancing act that is a fine line that Will take some time to get all sorted.
  8. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    If Axis 3a were for traction loss and one wanted to add a little sway there, would sway move in both directions or does it need to be assigned to 2 different dof's with the orange "Dir" button lit?
    153,788Coins
    +11,150 / 57 / -2
    Sway should be assigned to 2 different dof's with the orange "Dir" button.
    Do each axis/force individually, one step at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  10. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
