My dumb noobie questions
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MikeG, Nov 11, 2014.
  1. noorbeast
    153,764Coins
    +11,149 / 57 / -2
  2. MikeG
    MikeG Member
    Semi retired
    Perth Western Australia
    1,839Coins
    yup that's more like my estimates from the look of them.
    Forgive me for my weight obsession but building the boat i have had to save every kilo i can. Maybe i take it a bit far but i even made 2 glass dunnies to save 30Kg :rolleyes:
    Don't tell the wife but i was measuring her bum to see how wide i need to make the seat. Her bum is a lot wider than mine is.:D
  3. bsft
    Looks like you may need to build your own actuators then to get the required lift.
    @SeatTime is designing something currently
    Ian at BFF has actuator plans as well.
    They will work out still cheaper t build than buy commercial and do the job you need.
    153,764Coins
    +11,149 / 57 / -2
    Now that is what I would call an obsession :grin
  5. SeatTime
    153,764Coins
    +11,149 / 57 / -2
    I consider the Fanatec CSL seat expensive for what it is but if light weight is your aim it may have some design elements you could consider adopting for your custom seat build: http://www.fanatec.com/us-en/play-and-gaming-seats/csl-seat-us.html
  7. SeatTime
    Not a bad idea, but I wonder how it would survive the stains of a body in motion?
    153,764Coins
    +11,149 / 57 / -2
  9. value1
    14,237Coins
    Seats in a (soccer) stadium are vandal proof and reduce to the max…
    Maybe not very comfortable but light.
  10. MikeG
    MikeG Member
    Semi retired
    1,839Coins
    SeatTime
    It will have to be a custom seat to incorporate the pitch axis pivots.
    Have been playing with some power and inertia calculators but some of it is a bit beyond me i was a bit shocked that the inertia calculations only came up with about 100w for the roll axis and less for the pitch, I probably got it wrong. I get the impression most of my other assumptions are close to correct. It will be difficult waiting till i can start getting the pieces fired up. I think the seat will have to move up my list of tasks so i can start a few tests once i have it.
  11. MikeG
    MikeG Member
    Semi retired
    1,839Coins
  12. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Interesting find @MikeG...a nice compact way of doing heave.
  13. MikeG
    MikeG Member
    Semi retired
    1,839Coins
    yes nice if it works.
    Heave for me is difficult with the seat pivot 400mm away from the base of the U shaped arm. It would require a heap of torque to move it fast enough. I have been researching belts to do it but they would need to be quite huge from the specs i have seen but then i may be reading those wrong. Was going to ask the belt people to see if they come up with numbers similar to what i have worked out, will wait till i get started to follow up on that.
    These things would be awesome for a g seat as well i think, only 1 servo for each panel.
