my finished sim
Discussion in 'DIY Motion Simulator Projects' started by dradis, Feb 22, 2015.
  1. dradis
    dradis Member
    tig welder
    616Coins
    hello again mate finaly i can upload a nice vid as u ask for it
    • Like Like x 5
    • Winner Winner x 4
    154,322Coins
    +11,179 / 57 / -2
    Thanks so much for adding the video, it is great to see your rig in action :thumbs
  3. Blame73
    Blame73 Well-Known Member
    8,315Coins
    Nice work and rig. Seems it flexes a little on the front side (some kind of rebound)
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    bent steel is a nice touch. clean design too.
  5. Nick Moxley
    17,057Coins
    Wow there is quite the amount of flex in that front end, Dradis, I would highly suggest you find what's causing that and tack up some supports. Flexibility isn't your friend in this situation.
  6. dradis
    dradis Member
    tig welder
    616Coins
    thx mate but the upper frame is alloy ultra light ;). no heavy duty on my motors.
  7. dradis
    dradis Member
    tig welder
    616Coins
    flex is ok as the upper frame is alloy otherwise it will crack the weldings if its to stiff like it happens sometimes with a mtb;)
  8. dradis
    dradis Member
    tig welder
    616Coins
    ur very much welcome mate;)
  9. Nick Moxley
    17,057Coins
    Flex will only Dilute your motion profile's and force to motor's to hold against a small wobble the frame itself is doing. A properly structured frame would not flex Nor would it break the welds.
  10. RacingMat
    21,087Coins
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    imho eliminating oscillation is a concern also. oscillation will affect the overall experience and overwork the components. it creates excess heat, stress and wear on the moving parts.
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    still think the bent tubing looks cool.
  13. GusBiz
    GusBiz New Member
    Sales IT
    Melbourne, Australia
    486Coins
    DC motor, AC motor, Arduino, Motion platform, 6DOF
    @dradis, I noticed that you stuffed your cooling coils with heat paste. That must have been quite a big amount of paste you went through :) ? Were you able to measure water temp in and out and see what kind of heat you were exchanging?
