My first 2DOF seatmover project
Discussion in 'DIY Motion Simulator Projects' started by Godslayer, Apr 3, 2015.
  1. michto35
    michto35 Member
    france
    92Coins
    thanks for the sharing, very good job :thumbs
  2. Pit
    30,516Coins
    You can't scale the pots - Ardunio reads 256 different positions of the potentiometer. If you use much less positions (eg. only one turn of a 10 turn pot) you have less positions for the needed turn, which makes the turn jerky (big steps between the positions). Therefore you should use nearly the complete bandwidth of your pot.
  3. Godslayer
    Godslayer New Member
    483Coins
    2DOF, DC motor
    Okay, thanks for that info @Pit
    I already refitted the set of cheap chinese pots, got to play Project Cars tonight :thumbs
    @Pit your project is really awesome, when I'm done with all the fiddling and everything works as I want it to in my humble little Sim, then the next step will be a conversion to the same winches that you're using on your Sim, they're pretty impressive :thumbs
  4. alexis67
    alexis67 Member
    288Coins
  5. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
  6. Godslayer
    483Coins
    2DOF, DC motor
    Thanks @alexis67 and @francky foor :thumbs
    Okay, there is a change of plans for my sim, after it needed 2 small repairs on the connection between motor and lever I decided to not wait any longer and go the winch route.
    As long as I don't weld the connection, it won't hold for long, so gotta stop bothering and do it big :thumbs:D
