MY first motion Sim + traction Loss
Discussion in 'DIY Motion Simulator Projects' started by crammy, Mar 17, 2016.
  1. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    that's assetto running in the video
  2. SimBad
    SimBad New Member
    Australia
    327Coins
    Out of curiosity, why did you go with the 4 x HyperAXIS100 and not just purchase 5xSCN6 actuators?
    What is the main difference?
    Also - these actuators seem to cost an arm and a leg these days, is there some place where these can be obtained cost effectively so that I don't need to sell my first born child?
  3. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    The hyper axis are capable of lifting 100kg each and as my rig is really heavy at the minute and I weigh 14stone others would of struggled.
    When my house is finished and i have time,I'm going to look into other options with motors and gearboxes as long as they can lift the load. They would be a lot quieter
  4. SimBad
    SimBad New Member
    Australia
    327Coins
    They seem to me that they are manufactured by the same factory - i wonder what sets them apart from a technical perspective. From my research, the SCN6-040 series seems to be the best compromise between force and speed, almost identical to the SCN6-020 series under 100mm/s
  5. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    Not sure what makes them more powerful. The scn6 40 and 20 are good for joyrider style sims with a cv joint as they are not taking a lot of weight. If building that type of sim though I believe the scn5 are preferred as they are faster.
    The entire weight of mine is just sat on the 4 actuators.
    I'm having problems at the minute however after stripping, moving and factory resetting pc, I just can't get one to function. Shall be creating a post on this shortly for advice
    Edit--- i meant seat mover, not joyrider. i was just looking at other posts and realised
  6. SimBad
    SimBad New Member
    Australia
    327Coins
    I might send them an email asking to clarify specs of each.
    It might be the NEMA motor that differentiates them
  7. SimBad
    SimBad New Member
    Australia
    327Coins
    I contacted Frex, it seems that the AXIS100 are custom made by dyadic to handle 100kgs, so if i assume the threaded rod remains the same, then the nema motor is of a higher spec.
    Why are these things so damn expensive? Anyone have a "hookup" ?
  8. Dave Nichols
    Dave Nichols New Member Gold Contributor
    205Coins
    I suspect the 48V drive may also have something to do with it.
  9. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Hi crammy, really good job !I hope you have already been able to solve these problems and you're enjoying another go.
    Please could you explain a bit how is the wiring ConnectorPowerHyperAXIS, which wire goes to the source of 24v and which to 48v (+V and -V)
    Thanks !
  10. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    hi mate. all up and running again although not had the time to use it at present. ill try and find the wiring diagram for you and post it later on today
  11. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @Majony Ihave had a look on my pc but cant find the wiring diagram at the minute. ill see if i can find it printed off at home and scan it for you
  12. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @Majony wiring diagram as requested. sorry couldnt upload as a picture
  13. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    thanks crammy :cheers
  14. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
  15. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
  16. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Hi Crammy,
    Could you please share how you set up the traction loss? are you running any filters?
  17. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @helisfreak. ill have a look at the weekend if i get a chance and see how i set it up. its the Mrs birthday this weekend so not about much. i know that its set to 100%. I have added a filter but not to sure which. Off the top of my head i think its dead zone. without this the game was unplayable. the seat was bouncing left and right continuously.
    if you search the posts there may be information there somewhere also. i did ask the question and got some help but i cant find it now.
  18. liulong821170
    liulong821170 Think about the speed of the wind.
    Engineer
    NO.49 shixing Road,GuangZhou,GuangDong,China
    248Coins
    2DOF, SCN5, Motion platform, 6DOF
    welcome and looking forward to seeing your build process.
  19. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Hi crammy,
    You have Hyperaxis data wiring? Are two wires green and white, and the usb 485 have GND, P and A. How i connect?
    Thanks in advance
  20. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @Majony the wires for the conection to the usb 485 are red black green and white, so 4 cables. I cut the red of as its not needed, just leaving the 3 wires. I believe black went to ground, the +5v on the usb is not used and the green and white went to the other 2 connectors. I belive mine was labled GND, TX+, TX-, +5v. I read a post on here somewhere that you can get the green and wired connected the wrong way and it doesnt cause damage it just wont work. Make sure you dont put them to the GRD or +5v though.
    EDIT....
    I WILL CONFIRM THIS TONIGHT AFTER 5PM UK TIME. I JUST LOOKED AT THE COLOURS ON THAT USB CONVERTER YOU POSTED AND IT SHOWS WHITE AS GND. I DONT THINK THAT IS CORRECT SO I WOULDN'T WANT YOU TO CONNECT AND IS GOES BANG
