My new 3 dof
Discussion in 'DIY Motion Simulator Projects' started by el_marius90, Mar 23, 2023.
  1. noorbeast
    154,612Coins
    +11,190 / 57 / -2
  2. el_marius90
    el_marius90 Simracer simulador 2dof
    Electricista
    Madrigueras
    - 928Coins
    Hello, thanks for the help, I have a problem with the loss of traction, I've been looking at the simtools manual and doing many tests but I can't get it to work well, it has irregular movements on many occasions, could you help me?
    154,612Coins
    +11,190 / 57 / -2
    Can you please post pictures of all TL settings.
  4. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    that's the current setting
    154,612Coins
    +11,190 / 57 / -2
  6. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    This is how my 3 dof system is finished, thank you very much for the help, I really enjoyed the assembly, now it's time for the best hehe, thank you very much!!!
  7. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    One question, I would like to know if there is any information in the forum about cockpits created with actuators, especially if there are any with more conventional actuators than actuators as expensive as scn5
    154,612Coins
    +11,190 / 57 / -2
    It you use the Google Enhanced search on the Recent page you can find DIY actuators.
  9. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    Do you know where I can find information about connections and drivers and all that stuff? thank you
    154,612Coins
    +11,190 / 57 / -2
  11. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    Hello, I need help with a problem that I have, there are times when one of the motors shuts down when going downhill or when going downhill and braking, how can I find the problem?
  12. noorbeast
    154,612Coins
    +11,190 / 57 / -2
    First try and narrowing down the cause, are the motors exceeding the set control board limit, is a PSU shutting down, or is there a USB disconnect (often Windows sound notification)?
  13. el_marius90
    Electricista
    Madrigueras
    - 928Coins
    the motors do not exceed what is established on the control board, I have checked it, and I have two sources in parallel for that motor, one of 21A meanweell plus another that added 200w because I thought it could be the source, but I still have the same problem, the motor is 250w
  14. noorbeast
    154,612Coins
    +11,190 / 57 / -2
    If a motor shuts down that most likely relates to one of those three reasons, with overly aggressive setting being a possible contributing factor for any of them.
