My Sim Cockpit [2dof 24v]
Discussion in 'DIY Motion Simulator Projects' started by dedraro, Dec 3, 2016.
  1. Nick Moxley
    17,057Coins
    Incorrect, You do NOT need to heave the entire frame, Pit proved that a Simple Hinged plate on a seat mover is VERY effective at transmitting Heave.
  2. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I followed the project is very beautiful, but the feelings are personal so it is difficult to judge, I think the movement can cause problems with legs / pedals, hands / steering wheel;)
    ho seguito il progetto è molto bello, ma le sensazioni sono personali quindi è difficile esprimere un giudizio, credo che il movimento possa dare problemi con gambe/pedali, mani /volante ;)
  3. Nick Moxley
    17,057Coins
    Correct, feelings are personal and everyone has a different idea of whats right.
    This imo = Wrong....Not only in frame design, but overall motion profile.
  4. dedraro
    dedraro Active Member
    105Coins
    I think the best is 2 DOF for the seat + 4 DOF (dbox style) + traction loss, something like this (with a better setup, especially for the traction loss and with a better fov):
  5. Nick Moxley
    17,057Coins
    Lol ya that rig's a bit "over the top" :grin:grin
  6. dedraro
    105Coins
    Guys, I sent an email to get the code for simtools 2.0 more than a week ago, it is normal that still need answering?
    152,195Coins
    +11,064 / 56 / -2
    Things can go wrong. You can reapply and in the comments explain that you have submitted before.
  8. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    We will receive motors at the end of this month and our next order will be a mix of left and right motors ;)
  9. dedraro
    105Coins
    Thank you, then try again.
    Nice news, for the 4dof buy on simukit then. :D
    152,195Coins
    +11,064 / 56 / -2
    Have you checked your email spam folder?
  11. dedraro
    105Coins
    Yes,I checked and there is nothing, I only have 2 email confirmation receipt
    "We've got your mail. Please note that answering will take some time.
    The XSimulator Team"
  12. dedraro
    105Coins
    Although work is progressing slowly:
    Applied thermal paste and heatsink, on the two cards 43A IBT-2
    First test of the final position with the 2 fans
    Supports 3D printed
    Even printed a case for fans and cards, which will of course inside
    Also built the U-joint, also with a printed reinforcement 3d to 100% of pla, wedged inside the square tube.
    And the motors positioned.
    Now I began to wire and make the first tests with SMC3. See you soon.
  13. Nick Moxley
    17,057Coins
    Cooling on the bottom side of the chip ? That's not technically normal is it....Who suggested that ?
  14. dedraro
    105Coins
    No one, I just read that are more fresh more secure and are less chance that burn, so I put 2 fans :D
    guys, I have some problems to communicate Arduino and simtools 2.0, the engines, in SMC3 work and respond perfectly, while simtools, in testing output, I have no answer, so I think that does not communicate, this is the screen of interface settings. I think it's correct right? what else can I check? thank you so much.
    https://s7.postimg.org/5raxr647v/Immagine.png
  15. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    your interface settings are wrong should be like this
    and you can download settings from here https://www.xsimulator.net/community/threads/smc3-arduino-3dof.6410/#post-122034
  16. dedraro
    105Coins
    EDIT: ok I installed the preset, but don't work yet :S
  17. dedraro
    105Coins
    Ok everything worked, I was wrong in the selection of axes had put sway and surge, instead of pitch and roll in fact I realized by chance, I tried to move them a bit each and then I realized the mistake XD
    Today I begin the first tests with AC, hopefully good :D
  18. Wanegain
    Bruxelles
    2,003Coins
    I really like your DIY universal joint :p
  19. dedraro
    105Coins
    First test
    Unfortunately, when I take a bump too high or crash into a wall, the motor driver off for 2 sec, and it is not nice, I think they are the motor driver that do not hold the power, right?
  20. SeatTime
    Here's what you should do - Place order for Sabertooth drivers https://www.dimensionengineering.com/products/sabertooth2x32 :thumbs - cancel appointment with the hair replacement clinic :).
