My Sim Cockpit [2dof 24v]
Discussion in 'DIY Motion Simulator Projects' started by dedraro, Dec 3, 2016.
  1. dedraro
    dedraro Active Member
    124Coins
    I have 8 of these cards, I got them in the lot, a lot less of their price, you say you can not be connected in parallel as the moto-monster?
  2. Pit
    30,516Coins
    For sure @SeatTime can not be connected in parallel mode... :) Could you please describe to us briefly what you mean? MMs can be used as a single driver or dual motor driver, SaberTooths do not support single driver configurations - 2x__ Sabertooths are only dual motor drivers.
  3. SeatTime
    Were did I talk about connecting them in parallel? I know they are cheap, just like MMs and it took me allot of work to get sets of MMs to actually work - Your choice, your hair.
  4. ferslash
    ferslash Active Member
    4,798Coins
    about your boards disconnecting when you move fast the motors... i remmember that someone reported this error, and it was related to a lack of power in the psu... how many are you using?, maybe one psu per board
    or try to limit the amount of power each board takes.
    best regards
  5. dedraro
    124Coins
    Yes, for now I adjusted with the PWMmax 200, instead of 255, as I had done, and should be even better in very heavy shock never fall off.
  6. dedraro
    124Coins
    Finally completed everything:
    Many pieces printed in 3d, as a support potentiometers
    All electronics is placed under the seat:
    And of course, put an emergency stop button, to press for any problems.
    We catch up soon with 4dof project :D
  7. ferslash
    4,798Coins
    man, it looks justs grate, clean and elegant. :D 10+:popcorn
    Those motors you are using looks nice too, are they wiper motors? - if so, from what car you get them?
    best regards
    fer
  8. dedraro
    124Coins
  9. Wanegain
    Wanegain Active Member
    Bruxelles
    2,019Coins
    Or you can buy them on simukit.com for the same price with a faster delivery :p
  10. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    Can you share the STL files for your paddle shifters please
  11. dedraro
    124Coins
    I sell them
    I contact you privately for prices.
    PS: i broke a motor of 2dof :( I think switch the 120W motors with 350W soon...
  12. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Wow...much better, than i ever can build. And it looks expensive. :)
  13. dedraro
    124Coins
    Thank you, not so much, you have pm. ;)
  14. Diego Amaral
    Diego Amaral Member
    Rio de Janeiro
    98Coins
    I like it, beautiful finish
  15. dedraro
    124Coins
    New 350W motors arrived with the sabertooth 2x32A, will replace those 120W (will still be a 2dof, then in the future maybe I will turn it into 3dof by adding another 350W motor) bought by simukit (a special thanks to Wanegain, for many Info that gave me)
    I would use a 1200W 50A power supply I already had
    Mounted on the cockpit, they are solid!
    Printed gears for potentiometers
    And I also printed the cranks for motors, it's in PLA+ at 100% infill, weight 92gr one, I just hope they hold, otherwise I already have aluminum to do them, only I do not know where to find a 19mm drill bit to drill them XD
    Soon with the first tests :D
  16. Nick Moxley
    17,057Coins
    Sweet lookin motor's....Where did those come from ? Looks like your perimeters are a touch fast or slightly under extruded.
    When Printing Solid Solid Objects you really want to ensure your actually getting 100% infill with a Big of Extra filament added.......jump up your retraction to deal with the potential zits and pimples if you dont have your retraction number's down pat.
    What filament ? PLA .....have you tried any PETG ? Its stupid strong filament, try it out on your next order.
  17. dedraro
    124Coins
    It's PLA+, I also noticed that gap, however at the moment they seem to be fine, I did some tests, I installed the code for smc3 on the Arduino, I find it very good
    https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-w-softstart.9277/
    But the motors are too abrupt, they rush even in the slightest movements, I also tried connecting the potentiometers without reduced, so with 1:1 ratio, but it does not change anything. I think I have to add smoothing in smc3
  18. stevemontuno
    stevemontuno Active Member
    1,461Coins
    What's the gear ratio on those worm gears?
  19. Bastiuscha
    750Coins
    A high Kd value helped me with the same problem. And Kp not so high, are good too.
  20. dedraro
    124Coins
    These are the motors, have a lot of torque!
    https://simukit.com/moteurs/8-moteur-350w.html
    I'm also trying with ks at 20, and it goes much better, I also have to try to increase kd
    Anyway, I think now I print gears for potentiometers with a ratio of 1:1, I find it better than with 2,5:1.
