need for speed shift plugin
Discussion in 'Force-Sender & Plugins' started by riton, Sep 17, 2009.
  1. demon
    demon New Member
    and I almost forgot. Don't give up! Just because you don't see it...doesn't mean that it's not there, because it is...and you haven't seen it yet....D
  2. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    The whole process is really quite daunting when you don't have any experience with this kind of stuff. . :D
  3. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    More than a week and no new info. Well I guess everyone's stumped or given up. :(
  4. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Ok, you can come up with a solution now. I sold my copy of NFS Shift over the weekend. Between the stuttering, FF back problems and the fact that I couldn't use my rig, well I thought it was time to cut my losses. ;D
  5. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Any updates?
    By the way there are good mods available to practically remove the game sluttering and to correct FF settings ...
    With proper mods and camera adjustments this game is great! looking forward for this ...
    Bleco
  6. CXCSimulations
    CXCSimulations Member
    - 9Coins
    Yeah, I'd love to see a proper plugin for this. Let me know if there is anything I can do to help.
  7. yobuddy
    51,667Coins
    What up everyone, long time no chat ego! :cheers:
    I'll have some good updates on my sim soon - until then.
    Need for Speed - Shift - injector file online!
    SCN5 100mm Profile attached!
    After a whole lot of this - :? I finally got this - :yippiee:
    Let me know if it works for you!!
  8. bleco
    Montréal, Canada
    258Coins
    Hey yobuddy!
    Thank you very much for sharing your work! I wish I could test it now but I am still waiting for some parts for my cockpit frame... What plugin are you using with this profile?
    Thx!
    Bleco
  9. yobuddy
    51,667Coins
    Use the injector and look for a Need for Speed injector file by yobuddy on the online database.
    The main problem I had with most of the offsets that were found is that they are dependent on the orientation of the car to the track.
    Here are the offsets I used
    12357068 – Vertical
    12357080 – Pitch
    12357084 – Roll
    Pitch could also be:
    12357072 or 12357076 but I thought 12357080 worked best.
    The profile is only to prove the offsets work no matter witch way you’re pointing on the track. I’m sure someone could make a better one.
    If you need help – let me know.
  10. yobuddy
    51,667Coins
    Anyone give it a try yet?
    I would love to here some feedback.
  11. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Hi YoBuddy,
    Thank you for your injector file, however i cannot get it to work with your profile... the values do not match i think.
  12. yobuddy
    51,667Coins
    Were you able to see good data being sent to the injector file?
    Every time i load it up I have to re-select the - Step One Game Process? (Need for Speed™ SHIFT)
    Thanks for the feedback bro!
    For me to complete support for the game - I need all the feedback I can get! - so thanks
    Btw, I did some more testing last night and the only value that’s a little weird at the moment is the Roll value; I may search for another one.
    EDIT: I mistyped the roll value - lol
    after all that testing - :blush:
    Roll is 12357064
    Anyway I'd like to run some tests.
    The first test is below - it has a Profile and an injector file for Shift.
    Shift_Test1.zip
    - Without everyones help this would not be possible - so thx - No Game Should Go Unsupported! :cheers:
    @SirNoName - any way for us to be able to remove bad injector files we have uploaded - I hate to see such a nice tool get cluttered with bad files.
  13. splendiddd
    CCTV security
    Netherlands
    813Coins
    Thanks, i will test the files tomorrow. Hope shift will now work...its not a sim but fun anyway ;)
    And yes i need to reselect, but then the values show up at the profiler.
    Ill keep you posted.
    Regards,
    Rob
  14. splendiddd
    CCTV security
    Netherlands
    813Coins
    It works! Thanks allot, now i have something to work with.
    But the values are very low....@sirnoname: could you boost the values in the injector some zero's more? Or does that not make a difference?
    Thanks again, i will fiddle with your profile this week;)
    Cheers
    Rob
  15. yobuddy
    51,667Coins
    need for speed shift plugin working!!!
    Thx for testing it splendiddd! :cheers:
    I uploaded the new injector file to the online database, sure wish I could remove the bad one.
    I built the profile one step at a time, so I think it’s at least a good starting point.
    Can’t wait to see what you come up with!
    I did notice that the values were pretty low, but that’s why the values in the profile are low too.
    if there is anything else I can do to help, just let me know!
    Profile below - Injector file on the database under yobuddy - final
    thanks again for everyones help with this - have fun!!
    SCN5 - 100mm
    Shift_yobuddy.zip
  16. Popeyin
    Popeyin Member
    Truck driver
    Barcelona,Spain
    108Coins
    this profile runs with 150mm?i have to modify something parameter?
  17. splendiddd
    CCTV security
    Netherlands
    813Coins
    Okay, i first of all would like to thank Yobuddy for sorting out the injector values. :cheers:
    I had a lot of fun playing Shift tonight, especially with my frex wheel, the force feedback is pretty good for with my frex wheel ;)
    Also i adjusted Yobuddy's profile a bit: (nevermind the lambo comment, its pretty suitable for any car)
    SHIFTlambo2.rn2
    I fixed the speed (full) and acc. (50%) settings. also put a percent limiter on it 90%, i do not use the SCN5 interface limiter.
    I forgot about this game, because of the lack of motion, but even with only 3 values its really fun to play, the graphics and audio are suberb, sadly the psychics are not very realistic, nevertheless its great fun ! Thanks to Yobuddy for reminding :D
    I will make youbook vid this week for you guys entertaiment ;)
    Cheers,
    Rob
  18. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thank you for your efforts yobuddy. I will test and also work on a profile for this.
    ....Mike
  19. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I made a few modificatons to Yobuddy's profile as well. I'm having some issues with my G25 and NFS Shift where it has a ton of deadzone and I still have not found out how to resolve it yet so I haven't had time to test this profile properly.
    It has speed of 22500 and acceleration of 500 set in the synaptrix and has been setup for 150mm actuators with the 25% limiter on.
    Ledfoot NFS Shift v1.1.rn2
  20. splendiddd
    CCTV security
    Netherlands
    813Coins
    Thanks for the profile Mike!
    Its Great, mine is a bit harder, so i switch between mine and yours now depending on the type of car. I also inserted a smooth filter of 75% on my profile, good idea ;)
    BTW: strange that of the G25 deadzone, i have no problems with my Frex, did you check the controller settings? also use 50% of sensitivity, not less as many suggest, what rotation degree do you use? i use 540 degrees.
    :cheers:
    Cheers,
    Rob
