New 2dof simulator simtools + Jrk 12v12
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by gigi, May 29, 2014.
  1. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    I do not know if this site is a place to do thanks.
    But I want to make a special thanks to eaorobbie, He dedicated five hours of his time in skype to help me configure the adapters and jrk simtools
    THANK YOU ROB!
  2. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Good evening to all,
    I am completing the mechanical part of my simulator 2 dof,
    I chose the placement of the engines behind the seat mount above the shoulders.
    Using the gearmotors with 50: 1 ratio and 75 mm long lever. I currently have about 6 degrees
    pitch and about 12 degrees of roll.
    I would like to ask how many degrees should tilt forward and backward and pitch and roll sideways? What are the ideal values?
    thanks
  3. bsft
    as much or little as you like, you can adjust the profile so one doesnt move as far as the other.
    My desk racer has 17 deg pitch and 7 deg roll, I just fiddle the profile so the pitch doesnt move as far as the roll.
    The foot motor mount sim, had the opposite, 8 deg pitch, 18 deg roll, again, I worked profiles to make sure they moved fairly even.
  4. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    another question regards sim tools. when enter in game engine, interface setting and in presets i find Jrk 12bitbut If Ichoose it the option is not appear. why?
  5. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    this is the problem
  6. bsft
    its already set when you click the 12 jrk option, do not worry if it dissapears, the settings are there.
    153,788Coins
    +11,150 / 57 / -2
    What is the purpose of this and your previous posts to this thread @John Brown?
    153,788Coins
    +11,150 / 57 / -2
    Your spamming of this thread has been reported @John Brown.
  9. Nick Moxley
    17,057Coins
    IMO coins should be removed from said account when guys do this kinda stuff. :think
