News New 6dof+ AASD15 Servo Motion Controller
Discussion in 'Commercial Simulators and Peripherie' started by Motion4Sim, Oct 12, 2020.
  1. Motion4Sim
    Motion4Sim Member
    Europe
    705Coins
    Hi yes, check the store at motion4sim.com please...
    Yes was lot busy since a year. Will provide some contant here next time. there is also new board providing ethernet and much more new features in pro version.
  2. Motion4Sim
    Motion4Sim Member
    Europe
    705Coins
    Yes it handles all you need if there is something interesting new at your rig i can update fw
    Please also check the new documentation.
    docs.motion4sim.com
  3. Dirty
    All the way up front.
    7,963Coins
    CHeck here: https://motion4sim.com/
  4. Motion4Sim
    Motion4Sim Member
    Europe
    705Coins
    Motion4Sim Controller – Now with Ethernet, Advanced I/O & New PCB Layout (v2.03)!
    Hey everyone,
    It's been a while since the original Motion4Sim AASD Servo Controller made waves here. I’m excited to share a major upgrade with the latest Pro version and the brand-new PCB v2.03. This update adds Ethernet support, expanded I/O, improved safety features, and better compatibility with custom builds.
    New Pro Version – Ethernet Enabled
    The highlight of this release: native Ethernet support!
    • 100 Mbps Full Duplex for ultra-stable data
    • stable 2ms Datarate @ wired Network
    Redesigned PCB (v2.03) – Smarter, Safer, More Expandable
    The new PCB is a complete revamp that brings more control and flexibility:
    • USB Type-C for data + power
    • RJ45 port for Smart Handheld (w/ EM stop & Online switch support)
    • Secondary servo MCU for fault-tolerant operation
    • SPI support for RGB and OLED displays still in dev
    • EEPROM + Security chip for safe config storage and firmware protection
    Expanded Hardware I/O (NEW)
    This revision also brings a bunch of new connectivity options, perfect for more complex systems:
    • 0–10V Analog Output on Servo 7
      ➤ Ideal for DIY belt tensioner systems – no extra DAC needed!
    • 12V External Power Input
      ➤ Powers the controller independently from USB; ideal for pro installs
    • Brake Output Pin Header
      ➤ Trigger external actuators or brake systems directly
    • Secondary USB/FTDI Header
      ➤ Redundant or alternative connection
    • RGB 16x2 LCD Support
      ➤ Enhanced display options with color UI potential for Handheld and Onboard
    ⚙️ Key Features Overview
    • ️ Control up to 7 AASD servos
    • 1000 Hz real-time inverse kinematics engine (6DOF-ready)
    • Advanced motion filtering: low-pass, spike, custom
    • ️ Built-in or external 16x2 LCD and rotary encoder UI
    • ️ Compatible with SimTools, FlyPT Mover, SimHub, Dashboard Motionsystem
    • Auto-calibration, park mode, soft start
    • Customizable firmware
    • Support for external E-stop & Online switches
    • Integrated belt tensioner calibration & control
    • Support PWM Channel for Wind Simulator
    • EEPROM for profile saving
    • ⚡ Health monitoring and failsafes
    Buy & specs: Motion4Sim Controller Pro (Ethernet)
    Docs & setup guides: docs.motion4sim.com
    Steady Growth – A Trusted Choice for 500+ Users
    Whether you're a DIY hobbyist or building a high-end 6DOF platform, Motion4Sim delivers:
    • ⚙️ Stable, mature firmware, now with a robust Ethernet stack
    • Individually configurable actuator resolution for perfect motion alignment
    • Fast, clean, responsive motion – what we call UltraSmoothMotion
    And what’s even more encouraging:
    Many who’ve come over from other well-known DIY motion controllers say they’d never go back.
    Same hardware – totally transformed experience.
    Motion4Sim isn’t about hype – it’s about engineering, usability, and real-world performance.
    Build smarter. Move better. Enjoy more.
    If you're looking for a platform that just works – and keeps evolving – you might’ve just found your new motion brain.
    Cheers
  5. HUANGJIN
    HUANGJIN New Member
    machinery manufacturing company
    China
    204Coins
    DC motor, Arduino, SimforceGT, Motion platform, 4DOF, 6DOF
