Showroom Newbie with 2 dof
Discussion in 'DIY Motion Simulator Projects' started by jem45472, Mar 28, 2014.
  1. Nick Moxley
    17,056Coins
    How high can the JRK's go before your asking for trouble or excess heat or diminishing returns ?
  2. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    Im new to this myself, but if your just playing around till your bigger heatsinks come in I believe the jrks will shut themselves down if overloaded. Repeat dont take my word for it though.
  3. Nick Moxley
    17,056Coins
    Yes robbie confirmed that as well. I put the chip up to 180 and it didn't shut down so Obviously the chips can take quite the heating before going south. lol
    I was asking about the voltage limits.
  4. jem45472
    Buffalo NY
    97Coins
    Just remember heat is the enemy, dont try to push them too hard.
  5. Nick Moxley
    17,056Coins
  6. jem45472
    Buffalo NY
    97Coins
    I think I remember 16 being the max.
  7. Nick Moxley
    17,056Coins
    I dont think its that high......is it ? If so no worries as our Power supplies will shut down before 14v lol
  8. jem45472
    Buffalo NY
    97Coins
    "The powerful jrk 12v12 motor controller is a highly configurable brushed DC motor controller that supports four interface modes: USB, logic-level serial, analog voltage, and hobby radio control (RC). The controller can be used as an open-loop speed control or for closed-loop speed or position control. The continuous output current is approximately 12 A (30 A max) and the operating range of 6–16 V (with transient protection up to 40 V)."
    Appears so, crank that supply up!.
    Actually I also remember seeing somewhere that the p.s. might even go into protect mode pushing it too high. Might want to keep it somewhere around 13.2 or so.
  9. Nick Moxley
    17,056Coins
    Awesome, Ill probably shoot for 13.2-13.5v and worst case scenario bump it back down if it shuts down.
  10. jem45472
    Buffalo NY
    97Coins
    Ive been watching your thread eagerly. We are using same motors, power supplies, controllers, pots, and we are the same weight. You start yours on fire, Im going down a different path!:D
  11. Nick Moxley
    17,056Coins
    LOL No fires yet, boards were 100 degrees after a good 2-3 hour session last night with the small heatsinks, And i was running some Pretty WILD profiles trying to learn what does what. Your good to go buddy. :thumbs
  12. bsft
    as said, dont worry too much. One of the power supplies on my desk racer failed the other day, so one motor has 12v and the other 13.8v. There is some difference between the two with one getting more power than the other, but overall, once in game, I cannot tell the difference.
    12v is fine, really, dont panic.
  13. bsft
    I start mine on fire?
  14. bsft
    @Nick Moxley , do you run a fan over the top of them to cool them? I always so and despite the heatsinks getting too hot to touch with a finger and the motors needing fan cooling, neither have stopped.
  15. Nick Moxley
    17,056Coins
    yes i got a single fan going but will be adding a 2nd this week, Not really for temps as the hottest ive seen so far is 180 without the sink (moot point) and 120 with the sink and running a pretty wild profile with a 220lb guy in the seat. So when i Finally get my heatsinks i ordered and add the 2nd fan, i really doubt the boards will get above 120-130.
  16. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Sorry Moxley, are you talking Fahrenheit or Celsius degrees?
  17. Nick Moxley
    17,056Coins
  18. prodigy
    Croatia
    6,698Coins
    Than it's not that bad, 100F is about 38C, that's pretty normal for operating chip, ofcourse cooler is always better, but still, I thought you were talking about 100-120 degrees Celsius, that's like meltdown :)
  19. jem45472
    Buffalo NY
    97Coins
    Fans on motors too?
    120 mm fans ok for motors or ac powered?
  20. bsft
    fans on motors only if they get extra warm. any power fan as long as it blows air
