newby looks for plc and motioncontrollers
Discussion in 'Motor actuators and drivers' started by kermit, Feb 12, 2010.
  1. kermit
    kermit Member
  2. bsft
    can you please be more specific
  3. kermit
    kermit Member
    I finally can start the motors to turn clockwise at max output op 12,5 hz ,
    using the velleman card , therefore I have max 0-5 volts output to the inverters .
    But still looking how to turn the motors clock and anticlock wise at 50 Hz max,
    And can I use an Amplifier to get 10 volts output?
    what am I looking for regarding an amplifier
    I`ve treid the others that are using the inverters just like me , be no reply as yet
    regards Henk
  4. Swets
    Swets Member
    PLC Programmeur
    Holland/Krimpen a/d IJssel
    375Coins
    werk die al?
  5. caiubbo84
    caiubbo84 Member
    italy
    240Coins
    Hi kermit,
    yes you need a amplifier to get 10 volts,
    in this forum you can find a post that explane all....
    if i found the post, i'll post it here!
    regards
    Valentino
  6. kermit
    kermit Member
    Hi update,
    I have purchased AMC 1.6 USB with an 0-5 to 0-10 volt converter, and 24 volts PSU for cw and ccw direction(frequenty inverter),
    Have treid to use X-sim 3.0 but with no luck , installed Xsim2 and ac motor are working with 2 problems
    First I have no variable speed
    when reaching setpoint the gearbox is going up and down trying to hold setpoint
    Given value is 127 i see it overshooting to value 125 to 131 or set point 155 its going to 153 to 157
    I`m looking for proven software settings based on a 2dof ac motors with inverters and FSX flightsim
    regards Henk
  7. eaorobbie
    20,487Coins
    Wrong forum mate.
