Nimasix 6 DOF Simdesign
Discussion in 'DIY Motion Simulator Projects' started by Nima, Jan 14, 2010.
  1. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    531Coins
    hi,
    here are the first video.
    http://www.youtube.com/watch?v=IccaTPQmsb4
  2. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    WOW! That is really impressive Nima!
    Very well done!
    Sometimes, when I see these 3 heads w/ projectors I miss my old configuration... LOL
    Cheers,
    MY
  3. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Quick question...
    How are you doing your profiles?
    Emphasis on pitch and roll for the front actuators and Gs for the rear ones?
    Cheers,
    MY
  4. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi
    i make pitch an roll 85% on the front and 15% on the back.gs 10% front 90% back
  5. ralphvdberg
    ralphvdberg New Member
    Racecar/Porsche mechanic
    Netherlands
    277Coins
    Fantastic Niels!! Nice Job!! :clap:
  6. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
    Absolut :eek: Genial.
    Deine hinteren Actuatoren sind das SCN5 mit 150mm oder 200mm?
    Die scheinen sich auch noch zu bewegen sind die doppelt?
    Wieviel Beamer sind da im Einsatz?
    Ist das mit diesem Spider plugin möglich Actutoren so zu verschränken,dass man das Cockpit vorne auch noch mit bewegen kann?
  7. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Hi Niels.
    This looks to have promise. I like the idea of moviing the wheel and pedals if your are going to try for extreme seat movements. I can't exactly tell the configuration from the video though. Perhaps we could see some pictures?
    Also, toward the end of the viedo on the extreme movements, it seemed as if the actuators were struggling and as a result were moving at very slow speeds. The other 90% of the movements seemed very fluid and accurate. Maybe when you get your additional rubber bands, the extreme movements will be able to respond quickly as well.
    Nice work!
    :cheers:
  8. jakob
    jakob New Member
    Frankfurt
    313Coins
    Wooh! Thats a hell of a sim. Brilliant job, Niels!
  9. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Very nice Niels,
    The movements look very extreme (surprised that you can drive with that much movement :)). I can also hear the actuators in the rear struggling on the extreme lateral movements and sound like they bottom out a few times so I'b be careful until you get more rubber bands :).
    Thanks for the video.
    .....Mike
  10. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    thanks
    michael: die hinteren sind 150mm die vorderen 100mm tausch ich aber irgendwann gegen 150mm die 100mm sind dann für die 5. und 6. achse.die hinteren sind auf der bühne die von den vorderen scn5 mitbewegt werden.ich benutze 3 beamer.ich habe 2 pcs für die steuerung der scn5
    bernard:yes i must have more rubberbands (or dobbel scn5)and a littel more work on the profil.
  11. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi mike
    if i have so mutch moment only on the back sektion i don't can drive.but the moment mixet on both sektion is nice and correct feeling.
  12. egoexpress
    Good job, Niels :thbup:
    But, though the construction is impressive, I wouldnt like that much movement (at least if the screen does not move with the seat).
    I'd rather use the front actuators just for vehicle pitch and roll, and the back actuators just for long/lat g-forces.
    Well, matter of taste at the end.
    regards
    Btw, the name Nimasix 6DOF is a bit confusing, for a 4 axis simulator ;-)
  13. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi egoexpress
    in the beginning with the new sim i have test with only pitch and roll on the front
    but the feeling is better if you mixed all a littel.the name is correct i have 2 axis
    more i must have only 2 scns more than i have 1 axis for drift and 1 axis for move
    the sim for and behind.
  14. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Hi Niels,
    yeah - hell of a machine :clap: !
    There are so many different and HEAVY movements - is it still possible to feel ACCURATE movements ? Partially it looks like the whole sim is shaking and rumbling, but no single movement resp. effect is recognizable. TO ME it's a little bit difficult to evaluate if it's realistic enough or if it's a collection of really heavy movements. I'd like to test it by myself, hehehe :yes:
    Do you plan to use H-belts ? Seems that you are working hard on staying in your sim sometimes :D !
    But once again: Big respect - you created a mean machine !!!
    One question regarding the projectors: Are you using back-projection ? I haven't seen the shadow of your head in the left and right picture... Which distance from projector lens and screen do you have then ?
  15. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Thanks for the info Nima, makes sense to me! ;-)
  16. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi chris,
    the video i have make on iracing in daytona is many bamps.is a problem you don't can see the track on the video.i feel many more realistic now,only a littel thinks i must tweak in the profil.i must make all thinks on profiling new for the new sim.is many diffecel and i must test and learn again.but is in feeling only 10-15% what can i make better.today i want make seatbells.
    i use a projector for the middel screen from nec wt600 for 150cm screen you mast have only 30cm.on 60 cm you have a screen of 250cm.
    on the side i have acer hi must have 240cm for 150cm screen
  17. minikase
    minikase Member
    359Coins
    Hammer Action in dem Stuhl....fall da aber nicht raus, Niels ;)
    Good Work!
  18. Nima
    Glaser
    Bad Zwischenahn
    531Coins
  19. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi,
    i have make a new video.iracing car :riley track:mazda
    i have make many work on profiling and on my new sim
    i can drive all cars with one profil now.is it a very nice feeling
    on all cars.yesterday i have order a ibeam for the littel shakes and the rpmhttp://ibeam.de/
    http://www.youtube.com/watch?v=uRLPbVyaN3w
  20. R-eng
    R-eng Member
    San Diego, CA, USA
    28Coins
    I got a kick out of your version of Laguna Seca...transposed left-to-right. I was scratching my head for awhile trying to recognize it. Then after getting it, I saw that the Motec rpm scale was backwards also. I would say it were fair enough if it were from Down Under. ;-)
    R-eng
