Question No movement SimTools axis testing
Discussion in 'SimTools DIY Version' started by James Robbie, Nov 16, 2017.
  1. aspe
    aspe New Member Gold Contributor
    v.s
    arges.toledo .españa
    15Coins
    if I can add some light to the theme, the led of the arduino ... I think it is the indicator, when the tester starts the axis turns on but remains fixed in place of smc3 passes that constantly flash during communication.
    154,370Coins
    +11,179 / 57 / -2
    You really should start your own thread and post pictures of all of your settings, as it is likely either faulty hardware or incorrect configuration.
  3. aspe
    v.s
    15Coins
    maybe .. the idea was to have the thread with the finished project. the configuration I think is fine, the engines in smc3utils work perfectly the ip is configured correctly. (127.0.0.1) the pc that I use for the tests is a portable, the configuration of axes as in the images uploaded in this thread, and I read the 75 pages of the thread of the tutorial. The motors are new windshield wipers, properly isolated .......... the only one that gives me hope is that when I open the axes tester the LED of the arduino encinde when it finishes the account of 3.
  4. knightsy
    knightsy New Member
    retierd
    cyprus
    157Coins
    2DOF, Arduino, Motion platform, 4DOF
    I have same problem can not get moment in sim tools but motors move when i type i commands in Ardiuno serial conmands same set up as james.All on one computer .some one help pulling my hair out
    154,370Coins
    +11,179 / 57 / -2
    There is not enough information provided to properly aid troubleshooting.
    You really should start your own thread and post pictures of all of your settings, state what code you are running on the Arduino plus what other other hardware is being used.
  6. Marcos Loeps
    Marcos Loeps New Member
    178Coins
    Hi James, were you able to figure out what was the problem? I am having the same issue as you.
    154,370Coins
    +11,179 / 57 / -2
  8. James Robbie
    James Robbie Active Member
    IT Specialist
    New Zealand
    538Coins
    Hi Marcos,
    I wiped and started my project multiple times and there was probably a number of small subtle mistakes but I believe my biggest contributing issue was not setting everything correctly in the SMC Utility software. Once you have 150% proven behaviour in the SMC Utility software, then move on to SimTools.
    Hope this helps in some way
  9. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    Hi every one this is. My3rd day with the same problem works well with SCM utility but no movem
  10. Ayad
    Ayad Dr.
    surgeon
    Iraq
    - 435Coins
    Does any one find out how and what cuase the problem no update for the thread since 2018 best regards
    154,370Coins
    +11,179 / 57 / -2
    Please start your own thread and post pictures of all of your settings, state what code you are running on the Arduino plus what other other hardware is being used.
