Question No out put from Simtools
Discussion in 'SimTools Pro & Entertainment Version' started by Fluke, Jun 14, 2017.
  1. yobuddy
    51,769Coins
  2. Neman Ahmed
    Neman Ahmed Member
    Automation Engineer
    Karachi, Pakistan
    163Coins
    3DOF, AC motor, Arduino, Motion platform, 6DOF
    @noorbeast, what if someone having the exact same problem and it is due to the game plugin and he want to reinstall the plugin, what would be the sequence of steps he should take?
    154,807Coins
    +11,220 / 57 / -2
    In most cases it is a hardware or user configuration issue, not a plugin issue.
    It helps to first post pictures of all settings, on your own thread.
    Before messing with anything make a backup: https://www.xsimulator.net/communit...thout-loosing-your-profiles-and-settings.160/
    Then delete the Plugin from C:\Users\your_user_name\AppData\Local\SimTools\GamePlugins\
    You can install a plugin with the SimTools Plugin Updater, shutdown SimTools while using the updater.
  4. Neman Ahmed
    Neman Ahmed Member
    Automation Engineer
    Karachi, Pakistan
    163Coins
    thanks
