value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    The problem is that when I have this problem, I can't find any running Game Engine processes open in the task manager. Do they have any other names ?
    154,837Coins
    +11,227 / 57 / -2
    If you get the message that Game Engine is already running it is because it is right at the moment another instance is being launched.
    As I said the kill script I wrote is very crude, in that it just has a defined wait period between killing a process and then restarting it, there is not even basic checking to ensure the process has exited cleanly. How long a process actually takes to exit can be affected by many things, which can tie up system resources.
    I never really intended to refine or even release the script, it was just a crude hack for myself as I was annoyed with the NL2 bug. I don't intend revisiting or putting any time into the kill script, as I expect the issue with the plugin will be addressed at some point.
  3. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    Sure!
    Thanks for your help with the script!
  4. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Im trying to upload the plugin, but game manager is telling me the file NoLimitsSimulator_MaxMin.cfg is not Game Manager Profile... Does anyone know whats happening? Im trying to import it in game manager tool.
  5. value1
    14,306Coins
    Did you just drag&drop the zipped NoLimitsSimulator_Plugin.zip to the SimTools_PluginUpdater (in the SimTools installation directory)?
    (see https://www.xsimulator.net/simtools-game-plugin-updater/)
  6. Guilherme Bastian
    Brazil
    151Coins
    Yes I did. But after my post I discovered where each file should be installed and the profile worked. However, I couldnt make my sim wind work with it. No data is showing on dash 1...
  7. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I can confirm that the demo version, telemetry server does not work even if the active launch function steam --telemetry
    thank you
  8. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I confirm that with demo does not work but with the paid version okay
  9. Historiker
    Michigan USA
    9,212Coins
    Wow, this plugin paired with VR is amazing. 2 out of five of my nieces and nephews threw up after riding it yesterday! (Both made it to the bathroom first, and after cleaning up went back for another ride, and another, and another)
    154,837Coins
    +11,227 / 57 / -2
    They may be naturally sensitive but I would check your settings just in case to see if they are contributing to any mismatch between user visuals and vestibule systems.
  11. Historiker
    Michigan USA
    9,212Coins
    It was not an error, it was kids eating lots of candy and then riding a roller coaster :grin
  12. noorbeast
    154,837Coins
    +11,227 / 57 / -2
    Ahhh...the traditional fun fair syndrome!
  13. MarkusB
    4,215Coins
    Then I was lucky 2 weeks ago. My daughter had her 9th birthday, and one highlight of the party was the 10 kids riding rollercoasters with my rig and Oculus Rift. All of them had 2 to 3 rides, and luckily none needed the bathroom afterwards. Maybe because they did not have candies before, but only french fries. But their screaming was impressive.
    That brings me to the idea to use the Extra1 (speed) value for not only driving my 3 fans, but additionally triggering screaming sounds. This may again increase the immersion. :)
    • Funny Funny x 2
  14. value1
    14,306Coins
    Can anyone let me know, if the plugin still works, when you return to the main screen and start another ride?
  15. SeatTime
    Worked for me last time I used it.
  16. Ruszek83
    Ruszek83 New Member
    227Coins
    Does it work with the demo version ?
    If so.. how ? I did try for hours to get it to work with no luck... am i doing something wrong ? (all my other games work flawlessly)
  17. value1
    14,306Coins
    Telemetry in NLS only works with the full version.
  18. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    It does not. you have to add --telemetry to the startup command. But no the demo doesnt output telemetry.
  19. MarkusB
    4,215Coins
    Yesterday I tried NoLimits2 again after a long time (and after upgrading to SimTools 2.1), and I find the Surge DOF very snappy and sometimes delayed. And it often goes forth and back very hard where it should make a smooth movement.
    Even turning the "Smoothing" sliders in Game Engine to 100% does not make any difference.
    First I thought of a configuration problem and I checked the following:
    • My PID settings in the JRK config utility are rather smooth, because I am focused on flight rather than racing simulations. The motors make have a microscopically tiny overdrive movement in one direction, even when I am inducing a large abrupt position change.
    • I checked the Pitch force in NoLimits2, and this one is exactly as I would expect it. It follows the track very precisely.
    Did anybody else make similar experiences with the current version?
    Or would you recommend other values, like the new Extra1 to 3? (I noticed that they have changed, because previously Extra1 was filled with the speed value which I used for driving my fans. Now I am using GameDash for this. Works perfect.)
    Thanks a lot for any hint,
    Markus
  20. yobuddy
    51,775Coins
    Just some thoughts...
    Adding to much smoothing can case a bit of a delay.
    Are you sure that is not it?
    Have you tried using the 'Main' slider in the Game Manger, Profile Editor?
    It smooth's all of the DOF values, something that was needed with the fist game anyway.
