value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. yobuddy
    51,773Coins
    @reko19 ,
    I would too, but we are riding the direct data output from the game, so it must have been a lazy week at work for the game programmers. lol
  2. SeatTime
    So I was able to work out the changes required to the Quaternion Roll Calculation to get rid of the snap roll at the top of a loop - see video below. There is still a small amount of roll seen in the video below, but that is to be expected as it is not a perfectly vertical loop. As a bonus the change in math also remove the 0 to 360 transition issue as well without the extra math/code that I originally did for that :). Will do some more testing on different roller coasters to see if everything is stable.
  3. SeatTime
    Unfortunately each rollercoaster is not laser scanned like some modern racetracks, its just a simple asset built representation, so the tracks tend to be almost perfectly smooth including most transitions. I therefore use a ButtKicker mounted to a bonded post on the seat to impart some of the missing feedback via the sound track. Certainly adds to the immersion.
  4. SilentChill
    20,668Coins
    Great work with the plugin ;)When do you think it will be ready to share?
  5. SeatTime
    Just need to find the time to finish testing it for real on the sim, life keeps getting in the way :rolleyes:.
  6. SeatTime
    Ok, just too busy - here it is - any problems leave feedback. You will want to use Extra 1 for pitch and Roll or Extra 2 for roll. Note my Tuning Centre settings from the above video for a starting point. Have fun :). Edit : for some reason you will need to extract the files and drop them as a group into the plug-in updater - why? I don't have the time to investigate (I'm sure there is a reason)...
  7. SeatTime
    I was able to do some real tests in my sim tonight and while the roll now feels basically OK, the pitch just feels wrong. I have not touched the base calculation for pitch, so I decided to graph the data while it went through a straight loop... - well basically it does not feel too bad pulling into the loop (although the data shows it is half of what it should be) - it also feels odd pulling out although the data seems more correct at vertical. I going to see if I can fix it - just need to find some time :rolleyes:.
  8. SeatTime
    Found some time tonight :) - all fixed - needed completely new math for Pitch, which now tracks what you see in the sim - works great - tested on nearly all the roller coasters in No Limits 2. it was a pleasure to ride, with what I was seeing now completely matched to how the sim was moving :D. New Plugin attached - Note you have to extract the three files into a folder and then grab the three files and drop them as one into the Plugin Updater - if you have used No Limits 2 before, then that is all you need to do. Note my setup in the video above for initial settings. Update: Note that I have simplified the plugin so there is no need for Extra1,2 or 3.
    Have fun.
    • Winner Winner x 3
  9. SeatTime
    Video of No Limits 2 with the lastest Plug-in
  10. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    so, this is the latest one? as the same of PLUGIN downloads or only an add for correclty pitch?
  11. Joao Neto
    Joao Neto Mucilon
    Computer engineer
    Salvador - Brasil
    310Coins
    I understand it right, first I come with the main plugin, then I insert the 380 fix after the picth_roll fix? Or do you just need the picth_roll fix?
  12. yobuddy
    51,773Coins
    @Joao Neto,
    Just download and install @SeatTime 's No Limits 2 plugin above, and your golden.
    No need to install the original plugin first buddy.
  13. Joao Neto
    Joao Neto Mucilon
    Computer engineer
    Salvador - Brasil
    310Coins
    @yobuddy, When I just install it it does not seem like the option of selecting it in the simtools profile.
  14. yobuddy
    51,773Coins
    @Joao Neto,
    There is a couple of thing that could be happening.
    One could be that SimTools 2.1 needs to be registered to show more game plugins other than Live for Speed. (does it say demo in the upper right corner of Game Manager?)
    The other could be that your using SimTools 1.3, and this is a 2.0 and above game plugin?
    Remember thou, if your building a DIY Simulator, you can request a free DIY license here buddy.
    https://www.xsimulator.net/request-diy-key-simtools/
    Take care!
  15. Joao Neto
    Joao Neto Mucilon
    Computer engineer
    Salvador - Brasil
    310Coins
    @yobuddy, I have the key, and it is the simtools 2.1, but after I installed the original plugin appeared, then I added the seattime, apparently it is working. I'll do more tests here, thanks.
  16. yobuddy
    51,773Coins
    The new plugin replaces the old one, so you will not see two of them if you are expecting too.
    I know we will get it running for you !
  17. paulopsx2
    brasil
    649Coins
    The problem is that if you go on a roller coaster that is on the opposite path, ie backwards too, the DOF works, but the simvibe does not. In addition, the other toys in the parks, like EVOLUTION, ENTERPRISE or any other, do not reproduce properly the movements, nor the information of wind, vibration ... in fact, while you are in some of these toys, the platform continues with The movements of the last roller coaster that you walked. This is what I am trying to solve.
  18. SeatTime
    Simtools uses what ever is available via the NL2 Telemetry server, once it is enabled. The data you are looking for is either available, or it is not - http://dump.16vier.nl/nlhelp/index.html - my bad :oops:- look at the manual in the current version of the game (Help/Reference Manual/Telemetry Server). There is likely nothing anyone here can do - maybe an email to the NL2 developers?
  19. paulopsx2
    brasil
    649Coins
    i sent email on first try.. on may
  20. kjjcard
    kjjcard Member Gold Contributor
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    Hello.
    I have a problem with my game life.
    I have successfully completed the LFS test.
    I purchased NoLimit 2.
    I downloaded the plugin and applied it.
    My motion platform does not move.
    I changed the settings as far as I know.
    What is the problem?
    This is Google translation.
