value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    use --telemetry in startup options
    154,675Coins
    +11,207 / 57 / -2
  3. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    This plugins is it compatible with SIMTOOLS 2?
    154,675Coins
    +11,207 / 57 / -2
    Yes, but the plugin only works with the full game, not the demo version of NL2.
  5. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    OK thank you Noorbeast, I have the complete game
  6. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    I tried NL2 today but movement didn’t match the scene. While it was going up/down, it swirled right left, so I guess pitch and sway mixed up? Or i did something wrong? I have P3 from DOF Reality. Anyone having that issue?
    154,675Coins
    +11,207 / 57 / -2
    The Dir boxes being checked orange or not determines which way a force/axis moves, this is what SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    There is a thread for DOF Reality settings for various games, but I don't think anyone has added NL2 yet: https://www.xsimulator.net/communit...ject-cars-2-can-anyone-share-me-theirs.11273/
  8. Wanegain
    Wanegain Active Member
    Bruxelles
    2,021Coins
    I noticed that heave is most of the time equal to 1, which must certainly be the gravity.
    I believe values in Simtools are centered on 0, which means that there is a permanent heave force in action which makes the heave settings complicated in this game.
    Is there a possibility to change this value ? Add an offset on the centered value ?
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    Hi ! Isnt necessary to change this value, because sim tools makes this changes on sliders, buttons or adjust levels on game manager. Just put one of this options in opposite ways you wantto change !
  10. Wanegain
    Bruxelles
    2,021Coins
    Thank you for the idea but I believe sliders does not affect the centered value, they only act on the effect itself.
    There is "adjust levels" in Game Manager ?
  11. paulopsx2
    brasil
    649Coins
    Yes, works on strength for each effect. Ps: dont work on all games. Only tested on fsx, asseto and NLS2
  12. Wanegain
    Bruxelles
    2,021Coins
    So it doesn't solve the issue... :(
  13. BlazinH
    16,702Coins
    No there isn't. I asked for this during beta testing but the response was this should be handled by the motor controller since offsetting center in Simtools will cause more movement on one side than the other.
    Also gravity is technically always 1 so the plugin should be transforming the values as required for correct output.
  14. SeatTime
    Yep, it does 'Heave_MemHook = .G_Force_y - 1'
  15. Wanegain
    Bruxelles
    2,021Coins
    I just saw that I do not have the latest version of the plugin... :oops:
  16. Narendra Singh
    Narendra Singh Member
    23Coins
  17. Narendra Singh
    23Coins
  18. Narendra Singh
    23Coins
    i having problem to use this plugin with new version simtool i have old version plugin how can i use tat
  19. noorbeast
    154,675Coins
    +11,207 / 57 / -2
    Do you have a licensed version of SimTools?
    What version of the plugin do you have?
    Does the plugin install?
  20. Narendra Singh
    23Coins
    no i don't have license
