value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. noorbeast
    154,358Coins
    +11,179 / 57 / -2
    The demo version of SimTools has the fully functional plugin for Live For Speed, specifically for testing purposes. I would suggest you use that for testing.
    To use any other plugin you need a licensed version of SimTools.
    SimTools licenses can be purchased: https://simtools.us/license/
    But if you are completing a DIY simulator you can request a free DIY SimTools 2.0 license, conditions apply, see here for detail: https://www.xsimulator.net/request-diy-key-simtools/
  2. Sebj
    Sebj Active Member
    Canada
    492Coins
    Does the current plugin support No Limits 2 version 2.5.6.1?
  3. SeatTime
    I use the latest steam version (2.5.6.) of NL2 which works fine, but as the simtools plug-in uses the telemetry data provided by the NL2 developer himself, the plug-in breaking due to a version change should be very unlikely.
  4. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    it works very well, incredible the feeling, I only have a problem, I start a little inclined to the right, can it be corrected?
  5. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    This isnt a plugin problem. Your presets axis is align on self test menu?
  6. paulopsx2
    brasil
    648Coins
    Yes, perfect
  7. polybasss
    Burgos Spain
    155Coins
    in Simtools? Yes, and works fine with other games
  8. paulopsx2
    brasil
    648Coins
    Ok. Just put a feel old versions, and test again
  9. maute fabrice
    maute fabrice Drift sk1.vr htc vive
    30Coins
    Hello I have a problem with nolimits 2 the patch and good and the simulator is active at the launch of the Games but a faith install in the Mannege there is no movement that produces the simulator does not move it stays in the low position and in the tuning center nothing This UX passes the number remains a 0, should it activated the telemetry in the games if yes or? In Content Manager The small rectangle and blue I do not understand why it and not green thank you for your help and sorry I am French
  10. maute fabrice
    30Coins
    A yes and my version of NoLimits 2 and (2.5.7.1) 64bit Steam Standard Version license
  11. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    1. Non-Steam version:
      1. Create a shortcut to the nolimits2app.exe file
      2. Right-click ->Properties.
      3. In the Target field, add the following text at the end: --telemetry --telemetryport=1515
    2. Steam version:
      1. Go to your Steam library, right-click NoLimits 2 Roller Coaster Simulation
      2. Select Properties. -> Set Launch Options
      3. Type: --telemetry --telemetryport=15151
  12. maute fabrice
    30Coins
    Good evening thanks for your reply I did those you said to me in steam, launch option and I have cries--telemetry--telemetryport = 15151, but there is still no movement on the carousel
  13. yobuddy
    51,652Coins
    You need to do it just like he typed it with the spaces too.
    "--telemetry --telemetryport=15151"
    Take care,
  14. maute fabrice
    30Coins
    Perfect thank you I succeeded,--telemetry. So these all good the simulator turns well again thanks to you
  15. Moh M Bak
    Moh M Bak New Member
    - 185Coins
    Hello this Moh .
    I tried to add --telemetry first time it worked well but suddenly it stop working with Simtools .
    I tried to add --telemetry --telemetryport=15151 and 1515 . and I tried to add "_"
    pls help me
  16. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    I @Moh M Bak .
    Did you verify that the .exe file name is the same reported in GameManager?
    When you start the game, GameEngine switches to blue light?
  17. Moh M Bak
    - 185Coins
    thanks @ilbige for your reply.
    yes, I did .
    and it switches to blue light in Game Engine but no Axis motion on ti .
  18. Moh M Bak
    - 185Coins
    Pls look at the pictures...
    " it works great with Live for Speed"
  19. yobuddy
    51,652Coins
    I can't really see the target details in the last pic, but it looks like you don't have it right.
    Please copy and paste this in there (without the quotes)
    Chat soon,
  20. Moh M Bak
    - 185Coins
    Hello thanks for your help @yobuddy .
    I did it but nothing happen .
    and It was working but suddenly stopped ( No motion ) .
