value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. Horker
    Horker New Member
    154Coins
    ok thx but how you do that? i try to change exe file or shortcut but it dosn't work :(
    thx for your help
  2. Horker
    Horker New Member
    154Coins
    Ok sorry i find it
    It works very well !! Thx a lothug:
  3. Joseph Eilert
    Joseph Eilert Member
    Engineer
    - 95Coins
    Does Game Vibe work with the current plugin version? I am able to test my buttkickers in the Game Vibe sound card setup and get vibration, but in game they are silent.
  4. yobuddy
    51,771Coins
  5. Joseph Eilert
    Engineer
    - 95Coins
    Thanks yobuddy. I see that now in the update.
    Any thoughts on why my motion sim is functioning correctly, but the Gamevibe isn't sending through to the Buttkicker when in game?
  6. yobuddy
    51,771Coins
    Is Vibe output enabled in GameManager?
  7. Joseph Eilert
    Engineer
    - 95Coins
    Yeah it is. Hmmm I'm sure it's a super easy fix that I'm just not seeing. In the Gamevibe tuning center it is receiving Game input, but the Limits are staying at 0. Is that correct?
  8. yobuddy
    51,771Coins
    Ok, Then all you need to do is set some Hi/Low values in the Gamevibe tuning center and you should get some action!
    Take care,
  9. Joseph Eilert
    Engineer
    - 95Coins
    Alright well I got them shaking and almost shook my whole sim apart! Thank you for the help yobuddy.
  10. yobuddy
    51,771Coins
    Anytime buddy!
    Take care,
  11. Joseph Eilert
    Engineer
    - 95Coins
    :blush Hopefully by anytime, you mean now because I just ran into another unexpected problem. When NoLimits is running, the buttkicker constantly vibrates, even when I'm just in the opening menu and the Gamevibe tuning center is reading zeros. Ever run into this before?
    Edit: Did some further testing. It seems like it is coming through the Turbulence and Road Detail channels only.
    Edit2: I lied, it is just louder from the Turbulence and Road Detail channels. Receiving some vibration from Collisions too.
  12. yobuddy
    51,771Coins
    Sounds like you need to edit the Hi/Low file for the game in the GameVibe Tuning center.
    (btw, You can mute each output independently as to be able to work with one at a time.)
    Take care,
  13. Joseph Eilert
    Engineer
    - 95Coins
    Figured it out!
    For anyone that's running into a similar issue, I had to go into the Vibe Creator window and adjust the "When Input Data = 0%" setting for each of the vibrations used in NoLimits. Mine were all set to output at 20% volume when there was 0% data. Once I set all of the Data = 0% settings to Volume = 0%, the problem was fixed.
    I think NoLimits is continuing to output GameVibe data even in the menus.
  14. mimakez
    mimakez Member
    263Coins
    Does this plugin support the latest version of the game NoLimits 2(full game) with latest version of simtools
  15. noorbeast
    154,831Coins
    +11,227 / 57 / -2
    Yes, last I checked, with motion and Game Vibe support also available.
  16. IndependentEngineering
    IndependentEngineering New Member Gold Contributor
    - 63Coins
    Has anyone noticed intermittently illogical sway output for NoLimits2? I'm seeing very high sway values (like 8+ g at times) in tuning center at times when the coaster is going straight or when stopped. Surge and heave appear to output correctly. It also doesn't appear to be on all tracks, but is definitely present on colossus and at least a couple others. The accelerations displayed in the game's built in telemetry tool show correct output. Anyone else see this or have any solutions? Thanks!
  17. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    65Coins
    Bonjour,
    Aprés avoir telecharger la version demo 2.5.7.1 64 bits sur steam, et installé le plugin 2.01.1.17 puis activé la telemetrie sur steam, je n'obtient aucuns mouvement, avez vous une piste?
    cordialement
  18. value1
    14,305Coins
    NLR does not output telemetry in the demo version.
  19. Dronneau.Y
    france
    65Coins
    Ok, merci de la réponse rapide, il ne me reste plus qu'a envisager l'achat!!
  20. noorbeast
    154,831Coins
    +11,227 / 57 / -2
