value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. Surflinkcafe
    Surflinkcafe New Member
    - 38Coins
    I tired all the settings it won't move
    154,831Coins
    +11,227 / 57 / -2
  3. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    643Coins
    2DOF, 3DOF
    Click on the link above noorbeast and you will see how to activate telemetry for steam.
  4. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    I am running NL2 via Steam and simtools. Everything works fine but when I press ESC and leave the track and restart a new game the telemetry connection is lost. I have to close simtools and NL2 and restart everything and than everything works. any idea?
    @yobuddy
    Thanks Hans
  5. yobuddy
    51,771Coins
    We will take a look...
  6. yobuddy
    51,771Coins
    @hansvdm,
    Plugin fixed, update pushed to the repo!
  7. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    Yes it works now
    Hans
  8. VRLab
    VRLab Virtual Reality Motion System Platform
    CEO
    Palermo
    135Coins
    Hi friends, I need some help.
    I'm building my 6th simulator (four 2-engines, one 3-engines, and the last one 6-engines).
    I have always used NoLimits in my SIM 3 engines and it has always worked.
    Now I tried to make it work with the new SIM 6 engines but something is wrong.
    On Simtools everything works, the axes are adjusted well and from the tests carried out everything moves well (roll, pitch, surge, heave, yaw and sway).
    However, as soon as NoLimits starts, the Yaw goes all one way inexplicably.
    With Virtual Axis the values actually confirm this problem, the game issues an incorrect value.
    I can disable Yaw... but the plugin should apparently work without changing anything.
    Can you help me? The SIM is ready but I can't understand.
    Thank You.
    154,831Coins
    +11,227 / 57 / -2
    Is the computer language set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    It would also likely help if you post pictures of all of your settings.
  10. VRLab
    CEO
    Palermo
    135Coins
    Thanks for the feedback.
    I'll take some screenshots of Simtools.
    I also encountered the same Yaw problem with Project Cars so I assume it's a common problem with this data.
  11. Joao Costa
    Joao Costa New Member
    36Coins
    Hi There
    Did you found the solution? I have been looking at plugin data and G forces in game data, and i found that after 90º of pitch turning actualy it starts go down in other way, but vertical G force inverts.
    Im triyng to implement a new 4Axis simulator with 2x infinity 360º rotation axis for pitch and roll. I need to make some firmware code to see when in roll goes from -180º to 180, meaning that is rotating in same direction, but for pitch didn´t found solution yet as the plugin doenst provide vertical G force data do calculate and data is provided -90/+90.
    Converting pitch to -180/180 insted of -90/90 in plugin should solve this issue
  12. Specter20
    Specter20 New Member Gold Contributor
    Heavy Equipment
    Canada
    - 22Coins
    Hey all...
    I'm wondering if anyone can confirm if this plugin will work on No Limits Roller Coaster Sim 2. Since the first No Limits RCS isn't available anywhere I'm hoping this would work on part 2. Mostly want to get it for my kids
    Update...
    Never mind, it took me a while to find what I needed to find with a plugin from Global Wonders. Since I'm running off of the Steam platform I had to go to No Limits 2, then into settings (the gear) and select Properties. When that window opens up and right under where it says "Select launch option" there's a space where you can type "--telemetry". As soon as this was done it was working and responding... some settings in SimTools may or may not need to be touched up
