Showroom Obutto Ozone 2DOF to 3DOF simulator conversion
Discussion in 'DIY Motion Simulator Projects' started by scalhoun, Jun 25, 2014.
  1. Sebj
    Sebj Active Member
    Canada
    492Coins
    How long are your 14 gauge wire runs? Any issues with voltage drops?
  2. scalhoun
    scalhoun Active Member
    Software Engineer
    Pennsylvania
    968Coins
    10ft. No issues with drops or heat. I regularly check the lines and motors.
  3. Sebj
    Sebj Active Member
    Canada
    492Coins
    Sorry, one more question..is that 10 feet one way or return trip :)
    Using the gauge calculators I get 10 gauge for 14 feet total run roundtrip for 15 amps at 12V . You are making me feel better about running a thinner wire if this is the case. I dont even know if the JRK's will fit a 10 gauge wire or not, plus they are thick and more of a pain to deal with altogether.
  4. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    2 wire cable length is 10ft with, so if your counting a round trip it would be 20ft.
  5. Nick Moxley
    17,057Coins
    JRK power/motor connector's Will NOT take a 10awg wire, Maybe.....Maybe without the screw on connector and direct to the board with some fancy trimming of the core to fit Just So........
    153,836Coins
    +11,151 / 57 / -2
  7. Sebj
    Sebj Active Member
    Canada
    492Coins
    I'm going to go with 12AWG. It is 2mm in width so should fit into the connectors.
  8. Nick Moxley
    17,057Coins
    Pre tin the Tip your planning on inserting into the JRK connectors. Dont leave it bare copper wire.
  9. Sebj
    Sebj Active Member
    Canada
    492Coins
    I was planning on soldering it to the connectors as well.
  10. Nick Moxley
    17,057Coins
    You cant solder it to the Screw type connector...or are you talking about Hard wiring it directly to the board ?
  11. Sebj
    Sebj Active Member
    Canada
    492Coins
    If the 12awg fits I may not solder it to the board.
  12. Kattz
    Kattz Audaces Fortuna Iuvat
    Engineering Manager
    Ohio
    263Coins
    DC motor
    This is exactly the setup I have without motion that I want to add motion to. Do you have a video somewhere of the unit after the 3DOF conversion?
    Really nice job on all of it.
    Kev
