OCSM Sim (2dof + traction loss) project
Discussion in 'DIY Motion Simulator Projects' started by Overclockersmania.it, Feb 15, 2015.
  1. Overclockersmania.it
    Overclockersmania.it Member
    Cagliari, Sardinia
    20Coins
    @Wanegain: you were right my friend! It was the PSU. Today, switching to a good worthy of trust PC PSU completely solved the problem.
    I don't know why but although my PSUs are 1.2kW and my motors about 200W (measured with the clamp meter in game) those spikes cannot be handled.
    @noorbeast : which specific kind of issues? I initially had problems because the wheel was between the camera and the headset. Now it works really well compared to the previous set-up. Anyway something more can be done, for example put a damper in the camera pole to avoid vibrations to mess up the camera readings.
  2. SilentChill
    20,593Coins
    There aint no way in this world that the camera wont lose tracking, it will stutter and stammer and jump all over the place on a driving game. Flying Simulations work fine but not driving.
    If you find a miracle cure for the camera other than taking the tracking cable out of it I will pay you lots of $$$$$ for it :D
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,007Coins
    The problem doesn't come from the power (I'm sure you can easily get 1.2kW) but from the current peaks when changing direction at full speed.
  4. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    @SilentChill: I'm sorry due to my poor English I cannot get what you mean.
    In my opinion the camera can be used on rig, it's just needed a really rigid pole and eventually a good damper (or whatever system) to exclude all the small movements (produced by the ffb of the wheel for example, or by the rig itself).
    It would be great if the Oculus settings could provide a sort of deadzone..
    @Wanegain: Thanks again Wanegain!
    What I wanted to say is that the 1.2kW server psu is, according to specs, able to give 100A, while the PC PSU about 45A (I don't remember exactly at the moment).
    Theoretically, even in the hardest situation, the server psu should better handle peaks than the other one. No?
    In reality is the exact opposite.
  5. SeatTime
    Unfortunately those server power supplies are not designed to be used in our application and have protection circuitry that can get in the way of driving motors. I use simple LED high current power supplies and have never had a issue.
  6. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Hi all guys!
    I'd like to ask if there's a way to download the assetto corsa plugin which I already had without using coins again (I'm building a new PC and I cannot find the plugin file)..if not no problem, I will wait until I'll have the coins.
    Thanks in advance
    Marco:cheers
    152,445Coins
    +11,078 / 56 / -2
    Check your coins again and go grab it!
    • Friendly Friendly x 2
  8. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Thank you so much noorbeast! You are always so kind!
    I'd like to discuss with you and the others here in the forum about GMR sensors compared to Hall effect pots, is there anyone who tried them?
    I found this datasheet which seems quite interesting (only few drawbacks, like 4 wires instead of three), but I think I'll give them a try!
    http://www.infineon.com/dgdl/Infine...n.pdf?fileId=db3a304334fac4c601350f31c43c433f
  9. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Hall effect pots are a drop in replacement for standard photometers whereas the GMR listed is much like a rotary encoder, but hall sensing rather than optical. The GMR sensor that you have listed used a communication interface (serial/PWM) to talk to a computer/micro rater than an analog output.
  10. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Thank to all Forum for contents, support and patience!!!!!!!!!
    This is the final video to celebrate the end of the sim prototype.
    152,445Coins
    +11,078 / 56 / -2
    Sorry but the video is currently private so can't be viewed. :(
  12. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Sorry,
    It is public now!!
  13. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    This video show our solution for third movement! It Work really fast!!!
  14. Icefox
    Icefox Member
    549Coins
    congratulation for your simulator !would have a picture of your gear system for traction loss effect?
  15. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Tomorrow I'll post a new video! Thanks!!!
  16. Nick Moxley
    17,057Coins
    Careful on your TL Tuning center #'s. You can easily trick the inner ear into thing's that Are NOT actually happening.
  17. RacingMat
    21,055Coins
    Woah! Really fast and responsive traction loss!
    Well done :)
  18. asdfgg
    asdfgg New Member
    Mechanical Designer
    Pisa - Italy
    876Coins
    Bel progetto complimenti! :D
  19. RacingMat
    21,055Coins
    Could you please tell us what is the lever length and type of motor for your traction loss system?
  20. Icefox
    Icefox Member
    549Coins
    a picture of the system would be welcome :)
