Showroom ODESC - BLDC - 4 Dof Simulator (SMR 200)
Discussion in 'DIY Motion Simulator Projects' started by Will974, Sep 13, 2022.
  1. Dan82
    Dan82 New Member
    Pilot
    NRW, Germany
    39Coins
    Thanks for the reply. I'm looking forward to your shared files :thumbs
    Since I want to start gathering all the parts... Is there any specific reason why you chose 140KV motors and not 170KV or 190KV? Does it make a difference? I've seen someone use 190KV on a similar project here in the forum ... and now I'm confused...
  2. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    893Coins
    149 KV will permit you to generate more torque but you will have less max speed. Check the specification of your motor .... I use also 190 KV and it's enough for my use....
  3. Dan82
    Dan82 New Member
    Pilot
    NRW, Germany
    39Coins
    I do not have the motors yet…
    My considerations were that I have a heavy rig (160x40 profiles all around) and am not a lightweight myself… on the other hand I wanted to have a very responsive rig that can reproduce road and curb textures… so, which one would you choose with 1605 ball screw and 150mm range? 140, 170 or 190KV?
  4. Dan82
    Dan82 New Member
    Pilot
    NRW, Germany
    39Coins
    My considerations were that I have a heavy rig with 160x40 profiles all around and am not a lightweight myself. On the other hand I wanted to have a very responsive rig that can reproduce road and curb textures. So, which one would you choose with 1605 ball screw and 150mm range? 140, 170 or 190KV?
