Showroom ODrive Turnigy 190kv BLDC 6DOF - Here we go again
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Oct 12, 2019.
  1. SilentChill
    20,596Coins
    Little video of me testing a VR work around for FS2020
    Big thanks to @pmvcda again for giving me the chance to test his plugin for FS2020 :D
    • Winner Winner x 4
  2. diablomotor
    diablomotor New Member
    17Coins
    Which is the max supported weight for the driver/pilot of your 6dof system? Can the 6 motors move... how many kg?
    Great job! Awesome!
  3. SilentChill
    20,596Coins
    Probably around 400kg
  4. Icebeat
    Icebeat New Member
    - 61Coins
    Hi Silent, congrats on your Awesome work.
    Could you please tell me what power resistors are you using?
    What are the differences between your firmware and the standard firmware?
    How does the software know the Min and Max positions if you are not using switches?
  5. SilentChill
    20,596Coins
    Brake resistors ? 100w 0.5 ohm I think
    Lots of tweaks in the firmware I use that Insectatech made. And you define the min and max in the firmware
  6. usafltg
    usafltg New Member
    70Coins
    So I am trying to re-create this as we speak, and It isn’t clear to me how the rose heads at the ends of the actuators actually attach or what they attach to. Does anyone know or have a SketchUp of that? Once I figure that out, I can SketchUp a design for the seat frame. I just can’t seem to figure out what was used. To tie the actuators to the moving frame.
  7. SilentChill
    20,596Coins
    Rose join insert is what you need its in the sketchup
  8. usafltg
    usafltg New Member
    70Coins
    I have the rose joint inserts already, those are the loop inserts. I’m asking what do those actually connect to. In other words what goes through the loop rose joint. That’s what I can’t figure out. How does that connect up to the floating frame?
  9. SilentChill
    20,596Coins
    An M12 bolt goes through which is connected to the frame
  10. SilentChill
    20,596Coins
    I've been very quiet not much to report to be honest everything running great apsrt from a few mishaps caused by me. just too busy racing and enjoying the rig :D
    So I have been thinking for a while to upgrade the actuators to try and get rid of noise and wobble of the longer ball screws so here it is and i am currently printing and just waiting on my tubes to arrive
    [​IMG] [​IMG] [​IMG]
    I'll update my google drive with the new plans once I know it actually works and doesnt break/snap/fall to bits :)
    Also I have bought 2 oDrive clones from china they work just as good as the originals for less than half the price, which is the price they shoulde be selling for anyway, they are way too expensive
  11. SilentChill
    20,596Coins
    Mock up with spare bits I had, all seems to slide nice and easy time will tell :)
  12. Pit
    30,499Coins
    Unbelievable your progress since hour zero when you began to build the first 6DOF. While I stuck with my race rig still using heavy winches you entered an absolutely new dimension of building simulators. Bravo!
  13. SilentChill
    20,596Coins
    Thanks matey ! It never ends lol always something else to improve, or at least try to
  14. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    The design looks realy cool. And it should prevent tortion, in theory.
    Good luck with it.
  15. hannibal
    hannibal Active Member
    4,491Coins
    sexy stuff.. right here.
    i think i will follow your plans for my next build...im still trying to get your previous design working properly!
  16. eloverphx
    eloverphx Member
    Electrician
    Shakopee, Minnesota, USA
    297Coins
    2DOF, Joyrider
    Hey @SilentChill, Great build here. I'm looking at your files and was wondering if you could tell me where you go your u-joints on the bottom. Can't find a listing so I can get sizes that will fit in to the part you built. Thanks for your help..
    edit- also do you happen to have the stp files for the uv joint parts? would like to make some changes to fit my build.
  17. SilentChill
    20,596Coins
    Its all in my google drive :) page 7
    https://www.xsimulator.net/communit...dof-here-we-go-again.13879/page-6#post-194217
  18. SilentChill
    20,596Coins
    Slight upgrade , still quite noisy but better in a lot of other ways
  19. noorbeast
    152,706Coins
    +11,092 / 56 / -2
    As always a quick iteration from concept to reality, well done, looks to perform great :thumbs
  20. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Realy great set up !!!!
    Q =With your experience , Have you seen a big difference with the sweet spot of G1 vs G2 ? Because my G2 don't have a good sweet spot !!
