News Open source force feed back
Discussion in 'DIY peripherals' started by Hoantv, Oct 2, 2019.
  1. Thanos
    Electronics Engineer
    United States
    2,883Coins
    Hmm. That could work if I had a logitech g27 wheel... but all I have is the g27 shifter and pedals, and they attach and work via MMOS on the stm32f4...
  2. Hoantv
    Hoantv Active Member
    981Coins
    AC motor, Arduino
    @OZHEAT
    PWM and DAC of mode 0..50..100 was fixed in V0.19.2
  3. llluis
    Quebec
    1,631Coins
    Yes I can confirm this works. No power supply needed. I was doing this right before selling my G27.
  4. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    @Hoantv
    Great, thanks for the update.
    I will test and get back to you.
    Not having support for native g25/g27 shifter is not a big deal breaker and getting the fundamentals of the wheelbase workng is more important anyway.
  5. Hoantv
    981Coins
    AC motor, Arduino
    yes. the hardest is the wheelbase. other is easier :)!
  6. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @Hoantv
    I have been testing 0-50-100% mode
    Analog
    PA4 0.048-1.471-2.900
    PA5 1.460-1.463-1.466
    It is working ok maybe PA4 50% is not the same value as PA5 2048?
    PA5 drifts a bit but we are talking 6mV, maybe just set the value once instead of at each cycle.
    Digital
    PE9 0.002-1.467-1.434 but there is a definite glitch in the calc as:-
    ccw is ok as 0.002-1.467 (0-50%)
    cw is incorrect as it gets 1.467 (50%) - 1.520 (~51%) 0.002 (~52%) 1.434 (100%)
    It seems that you haven't implemented stop force yet, when wheel travels past wheel limits it looks like it just sets 0.048 on either limit.
    While it is ok in pulse and pwm mode as the wheel just goes in to freewheeling(0.048) it would be dangerous in 0-50-100% mode as if you over travel in cw it would command full cw and you it could cause someone to break their wrists, think of it like you are resisting the CW direction then over travel and then all the sudden the wheel goes in to full ccw(0.048) ouch!!. The correct command would be full CW (2.900).
    Also think about implementing in configuration setup to either have digital or Analog selection, no need to have both at the same time.
    It maybe causing the analog drifting.
    Anyway keep up the good work, you are definitely getting there.
  7. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @sedesa tatasa
    I guess I should say DXforce value.
    Out of a +/-10000 force value MMOS only utilises around +/-3000 any more and it will just clamp the output.
    Look at the clip LED connected to PD15
  8. Hoantv
    981Coins
    AC motor, Arduino
    Hmm, that is strangle :
    1) Digitial:
    Found problem in a formula => Solved in V 0.19.3.
    2) Analog:
    dacTotalForce = map(dutyCycle, -pwmPeriod, pwmPeriod, -4096, 4096); => calculate DAC value.
    Same as digital, only mapping from [-4096, 4096] to [0, 4096]
    HAL_DAC_SetValue(&hdac, DAC_CHANNEL_1, DAC_ALIGN_12B_R, (uint32_t) map(dacTotalForce, -4096, 4096, 0, 4096));
    HAL_DAC_SetValue(&hdac, DAC_CHANNEL_2, DAC_ALIGN_12B_R,
    2048);
    So if torque = 0 => it is mapped to 2048, same value as PA5.
    =>Which is max value in CCW and CW? maybe i misunderstood this.
    At the Stopforce:
    stopforce = (current encoder - max encoder)/(encoder ppr /9) * Stopforce configuration in GUI (around 10 degree)
    Totalforce += stopforce
    So it doesnt increase suddenly to maximum value. Stop force is configured in GUI.
    "Also think about implementing in configuration setup to either have digital or Analog selection, no need to have both at the same time.
    It maybe causing the analog drifting." => Yes, as i said before i will make 2 option. only choose one => after configuration DAC, PA5 is set outside loop, maybe value it does not change to much :)!
  9. Hoantv
    981Coins
    AC motor, Arduino
    I will add enhance to the firmware but display on LCD to show which effect is clipping.
  10. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    When I go past wheelcheck +/-10000 position the output will go to 0.048v
    To tell you the truth I don't see the function of the clipping as it shouldn't clip, the controller should be able to handle effect values +/- 10000, game clipping is different
  11. Hoantv
    981Coins
    AC motor, Arduino
    => increase sudently to maximum value?
    stopForce = setupWheelbaseConfig_Report.stopForce
    * (abs(motor.encoder.currentPosition)
    - motor.encoder.maxPosition)
    / (motor.encoder.PPR / 9);
    totalForce = wheelController.ffbEngine.ForceCalculator(
    motor.encoder)
    + stopForce * (motor.encoder.currentPosition)
    / abs(motor.encoder.currentPosition);
    This is the formular. It only increase suddenly if you rotate the wheel too fast more than update freq. but the update freq is 30kHz. So it can not increase suddenly.
    => in firmware, it already handle ffb in [-10000,+10000]. you said game clipping is different from clipping in firmware?
  12. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @Hoantv
    Now 0-50-100 digital is working properly and will stay at max when overtraveled, not in analog still goes to 0.048
    In force configuration-stop force it makes no change when wheel over traveled.
  13. Hoantv
    981Coins
    AC motor, Arduino
    I have rewriten endstop maybe fix the issue, the current version is v0.19.4
  14. OZHEAT
    Australia
    2,459Coins
    3DOF, DC motor
    @Hoantv
    Great, will try it out and report back.
    cheers
  15. Hoantv
    981Coins
    AC motor, Arduino
  16. Shadow Nightmares
    Shadow Nightmares New Member
    41Coins
  17. fzxj520
    fzxj520 Active Member
    1,341Coins
    Thank you very much!
    Who can publish the details of vnm + odrive?
  18. Vitor_vtrx
    Vitor_vtrx New Member
    23Coins
    Can I get support for the ForceFeedback-core-library project here?
    I want to use the project with the Keil/Stm32f103 compiler.
    I already have the whole project, but I don't understand how to use the FfbGetFeedbackValue function.
    I didn't understand the parameters.
  19. Vitor_vtrx
    23Coins
    solved.
