OpenVR-MotionCompensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Dschadu, Apr 19, 2020.
  1. HugoB
    HugoB New Member Gold Contributor
    215Coins
    3DOF, Arduino
    Thank you for your time, I will try this.
  2. HugoB
    215Coins
    3DOF, Arduino
    Did a clean reinstall of Steam, SteamVR and OVRMC, still no 'cog' visible. Other add-on overlays do work like fpsvr and 'OVR Advances Settings' and so on. Strange that OVRMC won't show up it's cog.
  3. HugoB
    215Coins
    3DOF, Arduino
    Solved it, had to do a clean install of Windows. Something was blocking it apparently. Works great now, thanks @Wagnard
  4. Warren Conn
    Warren Conn New Member
    - 15Coins
  5. Fahim
    Fahim Member
    553Coins
    So from my basic understanding;
    the two ways to allow motion compensation on high travel rigs are as follows;
    1) flypt mover which means you don't have to mount anything on the rig? Just have two lighthouses stand alone.
    2) sim tools; mount a sensor on cockpit and two lighthouses either side stand alone.
    is the above correct? The VR to be used will be PIMAX 5K
    edit: have also discovered a third methros with SRS studio; Witmotion WT901C (RS232) Sensor and Witmotion RS232 USB Cable
    Which is the most accurate way for a fast; high travel rig
  6. Bugge
    Bugge New Member
    16Coins
    Hello everyone,
    Does anyone know if ovrmc is working with a Pico 3 neo link? Or maybe a Pico 4?
    It's not in the 'supported HMD list'.
    It always crashes when trying to launch steamvr, but I'll experiment some more before giving up :).
    Thanks!
  7. MaxPower
    MaxPower New Member
    91Coins
    "edit: have also discovered a third methros with SRS studio; Witmotion WT901C (RS232) Sensor and Witmotion RS232 USB Cable"
    Witmotion is only 3-DOF so that is non-viable.
    Is there a way to use a Quest-3 remote as a reference point for 6-DOF motion compensation? Meaning, you mount the remote on the moving platform, check some box, and it all just works?
  8. MaxPower
    MaxPower New Member
    91Coins
  9. Guda
    Guda New Member
    2Coins
    I own a chinese motion simulator (VEGAFU) based on a headset DPVR E3C (via Steam) with a Chinese proprietary software. For now, I play a video inside the HMD and the motion moves.
    I look a way to add motion cancellation. I've read all this thread with interest.
    This E3C doesn't appear in the list of supported headsets but it should works because it's based on SteamVR. Anyway, I can’t choose another headset (the internal app is linked to this DPVR E3C).
    I wonder what are my options to add a tracker for OVMRC.
    1. I can’t access to the motion software so I can’t write a custom driver (soft tracker).
    2. I still have the option of adding a physical tracker, but this headset doesn't provide a tracker with this HMD. I though to use Vive trackers/base station but I read in one thread that “OVRMC does not support mixed tracking spaces”. Does it mean that I can’t add a physical tracker?
    3. I understand that a Wit motion sensor is only possible via SRS, which I can't use because (I have to keep a proprietary motion sensor). Am I right?
    Thank you for your advices
    Dan
  10. Flymen
    Montreal, Canada
    2,491Coins
    DC motor, 6DOF
    Hello everyone!
    I have HP Reverb G2 headset and recently installed with Oasis Driver.
    My problem is that before updating (Windows 24H2), everything worked fine with SteamVR, but my computer hadn't been updated for a year.
    So I waited until the Oasis Driver came out the spring... and now Oasis driver works very well, but it's not compatible with OpenXR or OpenVR Motion Compensation. I have no communication with it, and the three-colored crosshair doesn't move to center itself with my chair (FlyPT Mover).
    I'm looking for solutions... Am I the only one?
    Solutions:
    1 - Change headsets $$$$
    2 - Revert to a previous version of Windows... no way
    Thanks !
