OpenVR-MotionCompensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Dschadu, Apr 19, 2020.
  1. JMB3D
    JMB3D Member
    689Coins
    4DOF
    Hi Dschadu
    For a long time the community and others have been longing for a new dev to continue the great work Matazzaman done with the Open Vr emulator,
    I tried your version around 6 weeks ago and found it worked ok but reverted back to the original which for me worked better, probably because I've been using it for two years and just got so used to it, currently with the index.
    I'm going to be receiving my Pimax 8K X which has been a very long wait as one of the early backers, i will be trying all solutions to get that to work with my rig,
    I did have a Pimax 8k when that first came out but discovered it never worked with the open VR emulator, reported to Pimax who apparently fixed it, not sure how, i sold my 8k so never got to test it once they had fixed it, it took them months.
    What I'm wondering now and if any one can share is.....
    Does the PI Tool software have open VR Emulator built in?
    To use Pimax HMD do you still need to install an open VR Emulator to make it work with MC?
    When was your latest version released?
    Answer greatly appreciated so I can get this tested and post results,
    I will do testing with the index and both Dschadu & Matazzaman open VR, the same with the 8KX, will do a full set up guide with Pictures and notes for both once completed.
    JMB
    154,576Coins
    +11,190 / 57 / -2
    PiTools has motion cancellation built in, I am guessing they forked and patched Open VR emulator, but don't know for sure.
  3. JMB3D
    JMB3D Member
    689Coins
    4DOF
    Thanks it make sense it does, i know a request went in to Pimax to put a Set zero button in,
  4. Dschadu
    Dschadu Active Member
    1,938Coins
    OVRMC is stand alone. If your device is regonised within OpenVR, it will work with OVRMC.
    Latest release is 0.2.3, April 22. See page one in this thread.
    I highly suggest to read the posted readme and FAQ.
  5. Trigen
    Trigen Active Member
    2,892Coins
    Do you think this is within say 2-3 months of being able to test or are we talking 6-12 months? Im asking as im a few months away from where ill be needing it and if its 3 months away id save the controller funds
  6. Dschadu
    1,938Coins
    We are all no professional programers. We spend our spare time working on it. Therefore I cannot tell you any time frame. Sorry.
    I only can tell you that the Mover Driver is available in our discord and is working in its current alpha state. But as said, there is no timeframe for a release.
  7. RCFlyer
    RCFlyer Member
    United States
    139Coins
    Is motion compensation still not possible with the Rift CV1 and its external cameras?
  8. Phlames
    Phlames Member
    324Coins
    I wanted to know if this works with the oculus quest either via virtual desktop or link. I think when I connect the quest via virtual desktop it still uses the steamvr app for games to work so I should be able to use this with it. Im just not sure if it will work correctly with the oculus inside out tracking specially with the yaw axis. If it is working that will be great. I still plan to use it with my pimax 5k xr and vive light house set up but with the motion simulator I would like to use full 360 yaw wireless via quest and virtual desktop. I was also told on a discord that someone was working on a version of it that does work with the inside out tracking but I havent heard anything or any updates in a while.
    154,576Coins
    +11,190 / 57 / -2
    At the moment motion cancellation relies on outside in tracking using Lighthouse, so will not work in the manner you envisage with Quest: https://www.xsimulator.net/community/threads/openvr-motioncompensation.14576/
  10. Dschadu
    1,938Coins
    The CV1 with it's outside in tracking should work. The camera has to be stationary, of course.
  11. AndyB-ZA
    AndyB-ZA New Member
    4Coins
    4DOF
    Hi All (My first post)
    Used a huge amount of info from Xsim to get my Fasetech Racing cube working. (Many thanks)
    Im using Vive Pro with Tracker mounted on the top of seat for iRacing
    Just installed OVRMC after having some issues with OpenVR Emulator where the motion cancellation was just bouncing all over.
    After installing OVRMC i still had a similar issue but was solved by setting LPF to 0.00
    Although i had some movement, swimming i think you called it.
    Solved : Moved my Tracker onto the back of the seat so it was blocked from the front lighthouse and only picked up from the rear lighthouse (Maybe someone else is having something similar?)
    The new OVRMC is now working 100% and Im able to set LPF on any range.
    1.00 works perfectly, where 0.80 allows a little movement.
    Also the activation is much easier with a Single Click
    Thank you for this and keep up the awesome work.
  12. J-1775
    J-1775 Aviator
    1,624Coins
    That's an interesting idea, using a calibration process to create a compensation profile. Though primarily focused on WMR headsets such a solution would certainly open and help with many more motion and HMD hardware.
    I take the opportunity to rewarm another "open" solution or suggestion to our problem: https://www.xsimulator.net/communit...-needed-please-help.13226/page-6#post-190342;)
  13. J-1775
    J-1775 Aviator
    1,624Coins
    @Dschadu (or anyone who knows the answers): I'd like to give your slimmed down OVRMC a shot.
    a) Do I need to de-install OVRIE before I install OVRMC?
    b) For OVRIE I needed to install the patched DDL. Does your DLL already cope with the problems the patch was addressed to?
  14. Dschadu
    1,938Coins
  15. J-1775
    J-1775 Aviator
    1,624Coins
    Thanks Dschadu. I've found the answers, disabled OVRIE in Steam-Addons and OVRMC worked fine with the Vive Pro and a Tracker!
    However when I tried the StarVR, there was no compensation at all (whereas OVRIE works). When I can confirm that the StarVR hook might be the trouble I'll head over to the issues tab in GitHub.
    Thanks anyway, it's good to know that someone as capable as you cares for this tool which is absolutely essential for all VR fans here! :thumbs
  16. maximizador
    maximizador New Member
    farmer
    Galvez Argentina
    360Coins
    hello everyone sorry for my ignorance and for my english translated by google, the oculus rift s work with cameras too or are located in space using gyros and alcelerometers. In other words, the compensation program works for rifts or only for CV1 and another thing I did not understand is if you have to mount a controller that is used by hand in the simulator to detect the difference in movements
  17. noorbeast
    154,576Coins
    +11,190 / 57 / -2
    See the Supported Devices information for the Rift S: https://github.com/openvrmc/OpenVR-MotionCompensation/wiki/Supported-Devices
    • Tracker: Oculus Touch Controller
    • Result: Works, but jittery image
    Yes the controller would needed to be mounted to the rig where it can be seen and tracked by the Rift S HMD.
  18. Avee
    Avee Virtual Pilot
    1,167Coins
    I was able to use this with a Valve Index and HTC Vive Tracker.
    Are there any suggestions for physical vibration cancellation? I have used a suction camera mount to the back of my bucket seat to make the tracker sit proud over the back of the seat. This is very rigid, but transmits vibration to the tracker as well. Just making a flexible mount would possibly add vibration and wobblyness in stead of removing it. What we need would be flexible in the Z-axis, but solid with respect to horizontal movement. So a damper that is just sensitive in one direction. Is there anything from RC modelling like mini suspension components that would be suitable?
    Maybe mount the tracker on suspension and then add some mass to provide inertia?
  19. Avee
    Avee Virtual Pilot
    1,167Coins
    I found that quadcopter drones have accessories to decouple vibrations from cameras.
    https://www.ebay.com/itm/251872266912
    Since I didn't want to wait for shipping from china, I have just ordered some rubber buffers that I was able to get quickly, and I'll 3D print the mount.
  20. Fireblade69
    Fireblade69 New Member
    289Coins
    What exactly is the headset looking for from the tracker/controller? Is it an IR LED array that can be replicated easily using basic electronics and some creative 3D printing?
