OpenVR-MotionCompensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Dschadu, Apr 19, 2020.
  1. Dschadu
    Dschadu Active Member
    1,937Coins
    @Christian Hansen Current solution is only to restart SteamVR. I'm currently searching why this happens.
  2. J-1775
    J-1775 Aviator
    1,612Coins
    You might also check SteamVR settings/Addons (Start-Shut down/Addons): OOvrmotioncompensation must be ON. If you still have OOrinputemulator installed, it has to be OFF.
    Error may re-appear after changes you made on your system, thus I made this the first thing to check.
  3. Christian Hansen
    Christian Hansen New Member
    41Coins
    4DOF
    Thank you, so if I just keep trying it might eventually work?
  4. Dschadu
    1,937Coins
    Yes, restart SteamVR. I looked at the code and I have no idea why this happens... You can join our discord for a debug-build to help me track the issue down.
  5. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,978Coins
    Christian, Dschadu is trying to figure out what is causing this and he has recently posted on his Discord with some instructions and a request to those having this problem to help him track it down. Please find your way to his Discord and maybe you can help him get this fixed for you as well as for others having the same problem. =)
  6. Shaz
    Shaz New Member
    60Coins
    Hey All,
    I just wanted to drop here to share my excitement and gratitude for all this great work happening here. I am one of the Reverb G2 pre-orders and I cannot tell you how excited I am to get my hands on it. For the longest time I've been running an Oculus CV1 and ever since I got my motion rig "DOFReality P3" I had to revert back to playing in front of the TV. All I play is Dirt Rally 2.0 which is extremely "active" in the sense that I am constantly being tossed around from the G-forces. My biggest worry was motion cancellation. So to see this thread and this workaround makes me very happy. I obviously cannot test or use any of it yet but I will the moment I get my hands on my new HMD.
    Thanks for all the great work and I sure will be supporting this project financially as it truly deserves it. I cannot wait to get to enjoy it in person in my own rig.
  7. Christian Hansen
    41Coins
    4DOF
    Will do - also wanted to mention for anyone not seeing the overlay button in VR - In SteamVR under developer settings I had to turn on something like “allow overlays to modify global settings.” So if you aren’t seeing the option in VR that is likely the issue - I didn’t see this listed as a troubleshooting tip on the site so thought I would bring it up.
  8. benmax
    1,552Coins
    Hi, new here and happy to watch that a new motion compensation feature is on progress.I installed the .exer file but i always havemy actually serttings available with steam vr . I have the old motion compensation open vr input emulator which vorks with revive because i have a oculus rift . Is someone whoi could explain how to install the new motion compensation from Dschadu ?
    As my actually settings works i would like to test both if it's possible.
    in steam vr settings oovrinputemulator is YES , but into styeam vr when open settings only the old vr input emulator is available v1.3
  9. Dschadu
    1,937Coins
  10. benmax
    1,552Coins
    ok thanks will give a try and report ;)
  11. benmax
    1,552Coins
    ok got it , .exe wasn't installed !!! i had shutt down before installation finishing.
    ok now it works !
    Tested on assetto corsa competizione racing game , but the motion compensation is to slow vs the simulator movement (6 dof ) . it's like a big latency between movement and compensation .
    any advice for car games for compensation settings ?
  12. benmax
    1,552Coins
    ok for me it's quiet ok with LPS 0.8 and sample = 2.
    Like input emulator 1.3 with big yaw movement i've got a little bit also the black barel right or left (depending on CCW or CW sens of rotatoin ) on the oculus view ( border left or right ).
    But thanks for your job
    best results LPS = 1 sample = 2 hug:
  13. Trip Rodriguez
    3,978Coins
    I am cross posting this here from my own reply this morning on the old thread from the previous version.
    This post is about the issues with using Oculus VR gear with motion compensation.
    This is my best effort to somewhat succinctly explain my analysis of the problem we have when trying to use Motion Compensation (OVRMC or the previous much older OVRIE)
    3 "world spaces" exist when using VR
    1: The real world
    2: The VR world (pause menu etc.)
    3: The Game world (in sims this is the car or aircraft, not the world outside it)
    Motion compensation detaches the VR world and Game World from the Real World, and instead attaches them to the motion platform, solving our problems.
    OculusVR Compositor prevents Motion Compensation software from attaching the VR World to the motion platform.
    Unfortunately, the location of the window your computer draws for you to look through into the game world is attached to the VR world instead of to the Game World.
    The result is that when you use motion compensation with Oculus, the car will be attached to the motion simulator as desired when you can see it through the window, but the window is "stuck" attached to the real world so it will not always be in front of your VR headset as it should be.
    When the "window" into the game world is not properly placed correctly in front of you, you will see some of the blank black VR World around you where the VR world isn't being drawn because drawing it all would use far too much computer processing power and "normally" you would never see any of it anyway.
    That's a lot of worlds (and words)! I hope this makes sense to someone....
  14. rsbell
    rsbell Member
    334Coins
    Just wanted to say, “Great work @dschadu!”
    I could never get OpenVR to work with my rig, but this is flawless. It’s surprising how much better having MC is.
    I have a DOFReality P6 with Buttkicker and Pimax 8k+ (8kx delivers tomorrow), everything “just works”.
    Bravo and thanks! I’m off to the PayPal link to donate some well-deserved cash!
  15. dennis johnson
    dennis johnson Member
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    I have read all the posts in this thread and looked at the website for the program. It seems I cannot wrap my brain around what the settings actually do. I am using a Reverb with my 3dof SFX-100 rig. My controller is mounted directly in front of me on top of my steering wheel. I 3d printed a bracket so that the controller is rock solid.
    This program is excellent in that I am now not having to recenter my hmd every few seconds, but I am experiencing some strange issues while racing.
    1. screen jumping occasionally - probably due to my controller going to sleep. not sure.....
    2. Strange floating, swimming sensations - don't know how else to explain it....lol. It just feels weird at times...
    So, I want to mess with the setting to see if I can get a more rock solid experience. The problem is that I don't know where to begin.
    Are there any tips or suggestions on what to try to change and what results that I should expect when making the change? In other words, an explanation of each setting and what the numbers mean.. or some suggested settings for my particular setup?
    thanks in advance
  16. benmax
    1,552Coins
  17. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    144Coins
    I spent a couple hours trying to get motion compensation working with the oculus rift s playing Automobalista 2. Everything seems to be set up properly and enabled but it doesn't make any noticeable difference while playing. Steamvr is running but im not 100% sure its actually playing through steamvr and not the oculus software.
    Any ideas?
  18. J-1775
    J-1775 Aviator
    1,612Coins
    Just to find out: you may change any setting in SteamVR (video/audio) to an extreme that you'd easily notice.
    Also make sure, in SteamVR Addons, OpenVRmotioncompensation is on. In case of error, SteamVR may close all Addons and go for a "safe" start...
  19. Keith
    Keith Active Member
    Electrician
    144Coins
    Thats a good idea. I will try that. Thanks
  20. benmax
    1,552Coins
    Look at this discussion in the thread about this kind of issue !!
    It seems that you will not be able to get the motion compensation working ! I’m still in your situation !
    But if you have success please report !
