OpenVR-MotionCompensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Dschadu, Apr 19, 2020.
  1. Flymen
    Montreal, Canada
    2,503Coins
    DC motor, 6DOF
    Hi ,
    I have the Oculus Rift , but like I see , may be I will up grade and buy a new HP reverb G2 .
  2. janio
    janio janio from brazil
    state employee
    belo horizonte
    184Coins
    Hello, could someone explain to me how the flypt virtual tracker works exactly? how can he differentiate a displacement of my head to approach the plane's panel, from the forward displacement of the simulator by the dof pitch?
    because when I fly on the dcs, I need both controllers on the headset to have a perfect immersion.
  3. Flymen
    Montreal, Canada
    2,503Coins
    DC motor, 6DOF
    @benmax ,@SilentChill ,@hannibal @Pierre Lalancette
    Done , I'm on the waiting list !! ( oct /November ):) My Christmiss Gift 2020!!!
  4. hannibal
    hannibal Active Member
    4,492Coins
    congrats on your pre-order @Flymen. you will be happy with the product.
    I have the reverb G1 pro.. i am content with its capability over rift especially for simming.
    i might pickup G2 around holidays out of FOMO..
  5. Michael Mariacher
    Michael Mariacher Member
    644Coins
    4DOF
    Great product great work, thanks.
    Today I'd returned to my rig after several days off and motion compensation did not work anymore:
    The Vive tracker was still visible but could not been set to motion compensation mode, same with controllers.
    Unknown device mode 7 and device not tracking
    After some testing I could solve that issue with "opting out" from Steam VR betas. Unclicking this option, the last "real" version was installed and motion compensation is now working again.
    Michael
  6. Dschadu
    Dschadu Active Member
    1,938Coins
    Latest SteamVR version broke OVRMC and a lot of other add-ons. If you can, try to roll one version back.
    If SteamVR hasn't updated yet, disable auto update.
    I have to look what was changed exactly.
    154,729Coins
    +11,213 / 57 / -2
    I guess we have to be grateful that SteamVR has been pretty stable until now, thanks so much for being willing to jump in and sort out what has changed.
  8. Trigen
    Trigen Active Member
    2,892Coins
    Ive done the hard work in case you need to revert.
    Rename the SteamVR folder and unrar this into steamapps\common. It says 1.14 on version for me but its the 1.13 files and the Motion comp works.
    steam\steamapps\common\SteamVR
    Make sure X:\steam\steamapps\appmanifest_244210.acf is set to "StateFlags" "4" so it does not auto update
    "AppState"
    "appid" "244210"
    "Universe" "1"
    "name" "Assetto Corsa"
    "StateFlags" "4"
    "installdir" "assettocorsa"
    "LastUpdated" "1599120241"
    "UpdateResult" "0"
    "SizeOnDisk" "42632317740"
    "buildid" "5493711"
    "LastOwner" "76561197973293419"
    "BytesToDownload" "7632"
    "BytesDownloaded" "7632"
    "AutoUpdateBehavior" "0"
    "AllowOtherDownloadsWhileRunning" "0"
    "ScheduledAutoUpdate" "0"
    "StagingFolder" "1"
    "InstalledDepots"
    https://drive.google.com/file/d/1P-B2OyqFuvJG-3Dxx9JwTex-MZeDZlvq/view?usp=sharing
    https://www.reddit.com/r/SteamVR/comments/enhiva/is_there_any_way_to_revert_steamvr_to_a_previous/
  9. Avee
    Avee Virtual Pilot
    1,167Coins
    Thanks for your efforts, but for me it shows 1.14 and the dates of the bin files are today. OVRMC says device not found. So I am not so sure this is 1.13.
  10. Dschadu
    1,938Coins
  11. Michael Mariacher
    644Coins
    4DOF
  12. Avee
    Avee Virtual Pilot
    1,167Coins
    My SteamVR keeps crashing whenever OVRMC is enabled. I have tried uninstalling OVRMC and SteamVR, then reinstalling both. It still crashes after a short time. Not even running any VR application, just looking at an empty VR landscape.
  13. Avee
    Avee Virtual Pilot
    1,167Coins
    Is there anyone else with SteamVR crashes with 0.3.2, or is it just me? Any hints what apart from reinstalling SteamVR and OVRMC could be done to fix it? I have looked for SteamVR logs, but unfortunately, in the logs I found, there is nothing that is connected to the crashes. It just stores an empty crash log.
  14. janio
    state employee
    belo horizonte
    184Coins
    friends, to use OVRMC do i need to download the dcs via steam or can i just launch my dcs (not esteam) through the steam platform?
  15. Avee
    Avee Virtual Pilot
    1,167Coins
    OVRMC is a plugin to SteamVR. It will work with any program that uses SteamVR for VR, irrespective of where you bought it.
  16. Foxyfoxy
    Foxyfoxy New Member Gold Contributor
    - 115Coins
    2DOF, DC motor, Arduino, 4DOF
    Yeah, me too, actually crashing with the 0.3.2
  17. Foxyfoxy
    - 115Coins
    after many re install properly of steamvr and OVRMC
    ....it doesn't work,
    information, i have valve index, only when i start the valve index controller, when it's detected, steamvr crashes immediately
    maybe users of other materials could play
  18. janio
    state employee
    belo horizonte
    184Coins
    avee, i'm happy to know that. thanks for helping me. it has been difficult to understand everything that is needed for my platform to work.
  19. Foxyfoxy
    - 115Coins
  20. Dschadu
    1,938Coins
    If you are experiencing crashes, please provide a detailed error description (OS, HMD...). Please don't write your description in a rush and double check if a 3rd person would understand your situation.
    Also the log files are needed:
    https://ovrmc.dschadu.de/en/faq#where-are-the-logs
    Otherwise I'm not able to help.
