OpenVR-MotionCompensation
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Dschadu, Apr 19, 2020.
  1. Avee
    Avee Virtual Pilot
    1,167Coins
    Thanks!
    SteamVR crashes as soon as I move the headset i.e. the headset becomes active. I have a Valve Index on Windows 10 Pro v.2004.
  2. Trigen
    Trigen Active Member
    2,891Coins
    Here's a vid with Ptmover and software tracker + OVRMC
  3. janio
    janio janio from brazil
    state employee
    belo horizonte
    184Coins
    I couldn't see if it has a tracker attached to the platform or does this ptmover use a virtual tracker?
  4. Trigen
    2,891Coins
    It uses the virtual one
  5. BAER
    BAER New Member Gold Contributor
    washington
    137Coins
    This use to work perfect. I updated it via the "fix" from the previous page and now it's super laggy so the dash is floating around instead of it being still like before. Using Index, with OG Vive remote mounted to seat.
  6. janio
    state employee
    belo horizonte
    184Coins
    have you tried using the FLYPT virtual tracker? I'm trying to understand this new feature because I don't want to miss one of the touch controls, which would be tied to the structure of the simulator.
    I appreciate any information.
  7. Dschadu
    Dschadu Active Member
    1,937Coins
  8. Dschadu
    1,937Coins
    @Avee Would you mind to join our discord, or upload the log files to i.e. pastebin? I'm not going to invest 30 coins to download the log files, sorry.
  9. Avee
    Avee Virtual Pilot
    1,167Coins
  10. janio
    state employee
    belo horizonte
    184Coins
    dschadu could you help me? windows won't let me download ovrmc, you mentioned on the site using the source code but i don't understand how to do that, i've disabled all windows 10 security and the idiot keeps blocking. any alternative?
    thankful.
    solved, the problem was simpler than it seemed, I just allowed window to keep the file despite the warnings of possible malicious software.
    thanks and sorry.
  11. Pit
    30,512Coins
    FINALLY I got a spare time to drive my sim, just jumping in and installing the latest version of your tool..no motion compensation unfortunately. The first beta version 1.1 worked without any issues...today I am going to roll back to 1.1 if the issue still persists. Yesterday I tried a lot of different things while trying to find a solution but no way.
  12. janio
    state employee
    belo horizonte
    184Coins
    I have the same problem, two whole days trying to make it work, but despite setting everything up correctly, nothing happens with my f5 3e dcs plane. i use the culus rift s, is that the reason?
  13. Pit
    30,512Coins
    I'm on Pimax5k+, so slightly different from your setup ;)
  14. janio
    state employee
    belo horizonte
    184Coins
    the developer says that the ovrmc doesn't work well with oculus, so I must wait for my hp g2 to arrive to be happy, (laughs).
  15. prime97
    prime97 New Member
    Sydney Australia
    143Coins
    I have it working with Pimax 5k and Vive tracker and two SteamVR base stations.
  16. Curtis Jackson
    Curtis Jackson New Member Gold Contributor
    30Coins
    So I'm using a vive tracker mounted to my racing seat (6DOF platform) but having alot of issues with the image moving once motion compensation is applied using this. I do have quite a bit of transducers in my seat for haptic feedback so I'm sure this is why I'm having my issue (I cant dampening enough to stop this from happening.) but my question is if I were to use a virtual tracker would that solve the issue of using transducers on my rig? If it does I'm lost with how to create & set up a virtual tracker. Can someone dumb it down for me?
  17. Dschadu
    1,937Coins
    A possible solution could be to dampen the tracker mount and make the tracker side of this mount a bit heavier (+0.5kg).
    I wouldn't recommend the virtual tracker at the moment as there is a tracking bug which hides itself very well.
    If you still would like to test it: https://ovrmc.dschadu.de/en/vt_flyptmover
    If you don't know what Mover is or how to set it up, this driver might not be for you.
  18. twack3r
    twack3r New Member
    42Coins
    This is huge!
    What version of OVRMC and PiTool are you using?
    I have been looking to get this working with an 8KX for weeks!
  19. prime97
    prime97 New Member
    Sydney Australia
    143Coins
    I am using current versions:
    PiTool V1.0.1.262
    OVRMC v0.3.2
    My start-up sequence is:
    1. start motion platform software
    2. start PiTool
    3. start Steam
    4. start rFactor2 launcher
    5. run startdesktopmode.bat (from C:\Program Files\OpenVR-MotionCompensation) which opens motion compensation window and starts SteamVR
    6. switch on tracker and select it in motion compensation window
    7. in window, check the "enable motion compensation" checkbox and click "Apply"
    8. check that the status shows that motion compensation has been applied ("motion compensated")
    9. start rFactor racing
    I have the tracker mounted on a frame just above my head and backward-facing. I have lighthouses at 11 o'clock and 7:30 o'clock. It seems that it is best if, when doing the above, that only the forward lighthouse can see the headset.
  20. prime97
    prime97 New Member
    Sydney Australia
    143Coins
    Despite my post above about success with the Pimax 5K, I have also get the HP Reverb working with the right controller attached to the top of a stick strapped to the wheel frame (hi-tech!). The controller is slightly above head height and just the other side of the wheel.
    This setup gives me a better motion-compensation experience. With the Pimax 5K I am more aware of moving around in the cockpit under braking/acelerating/turning. It is still good with the Pimax but better with the HP Reverb setup.
    Also I prefer the better resolution of the HP Reverb although I am giving away the wider FOV of the Pimax 5K.
    Start-up instructions are as in the previous post except that instead of starting PiTool, I start Windows Mixed Reality.
