value1
pCARS2 Plugin 2.0.5.4
SimTools game plugin for pCARS2
  1. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    I did everything but still no motion.. I dont know if there is a problem with ports.. or something.
    EDIT: not a port issue, because AC is using the same port and its working.. :(
    EDIT2: After two hours of settings.. i still have no motion.. Anybody else with this problem?
  2. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Even when i play Pcars2 i see the logo of AC on Game Manager.. i dont know if it is an error or what is happening..
  3. value1
    14,294Coins
  4. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    No problem but was thinking was my fault.. i think i did everything to make it work.
  5. Vboull
    Vboull New Member
    181Coins
    It's work with the commercial version ?
  6. value1
    14,294Coins
    Yes
  7. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Yes, pCars2 works well with Simtools pro.
  8. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Here i cant get motion with this plugin on Pcars2.. :(
  9. exiledslinky
    exiledslinky Member
    Edinburgh
    334Coins
    @MorciXL have you patched the game or just copied over the plugin..
  10. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    I have patched it, and i can see how menus turn into blue when i start the game. Also i put shared memory on Projects Cars 1, UDF NO, and the last option on Project Cars 1.. with no luck.
    Also tried choosing Project Cars 2, but it doesnt work.
  11. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    I even installed the lastest update of Sim Commander 4, and simvibe worked on first attempt.. Dont know whats happening here.
  12. Coop
    Coop New Member
    England
    147Coins
    Can anyone please advise what the in-game UDP frequency should be set to? Off or somewhere between 1 and 9 (9 being fastest).
  13. value1
    14,294Coins
    The plugin does only use shared memory. UDP is not needed.
  14. Coop
    Coop New Member
    England
    147Coins
    Thanks. I had it set to 'Off'but just wanted to be certain.
  15. yobuddy
    51,744Coins
    Is the same comport use for anything else?
    meaning, if 2 apps try to use it, maybe the one that starts up first works?
  16. franccac
    franccac New Member Gold Contributor
    Barcelona
    32Coins
    I have problems too. I had ProjectCars 1 working and other games like Assetto Corsa. Now with Project Cars 2 installed, Project Cars 1 don't work too. I use the SMC3 utility to verify the motors funcionality, it's okay. After It I open Game Engine and Axis Testing works fine. I open Project Cars 2 and I see Virtual Axes moving, so the comunication with the game is fine, but the comunication with arduino stops, and if I stop the game conection in GameManager ang try again the Axis Testing it don't works. I have tried it several times. It's the same problem of yours?
  17. Vboull
    Vboull New Member
    181Coins
    I have the same problem.
  18. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    I have a similar problem with sim tools appearing to work correctly (menu turns blue) however there is not motion.
    By accident I forgot to turn on my SLI display and the motion works fine.
    Turn on the SLI display again and the motion doesn't work.
    Maybe just a coincidence but something to consider. For me it's the SLI plugin needs to set the shared memory to PCars 1. Obviously there is then a miss-match between the shared memory data. Or that's my thoughts anyway.
    Andy
  19. noorbeast
    154,693Coins
    +11,210 / 57 / -2
    The plugin download page has this: Please note: Shared Memory is turned off by default, and switched on via the Options screen, under Options→System→Shared Memory→Project CARS 1
  20. Andy Booth
    Malaysia
    430Coins
    I may be mistaken (and I'm not anywhere near my gaming PC at the moment so I could be wrong) but I seem to remember the PCars 2 shared memory screen shows it set to (in this case) Project Cars 1.
    I actually get an error screen come up but can't remember what it says.
    I'll take a couple of screen shots tonight and post.
    But I think it's more a problem with the SLI display than SimTools. But that's an uneducated guess. I really don't have a clue what I'm doing.
