value1
pCARS2 Plugin 2.0.5.4
SimTools game plugin for pCARS2
  1. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    I am so glad that little dialogue box has been dispensed with, it was annoying as hell, plus we have the bonus of Game Vibe support.
  2. Jordi Rafart Ribera
    Jordi Rafart Ribera New Member Gold Contributor
    Barcelona
    - 24Coins
    I also have trouble starting the vibration. Sometimes it works and sometimes it does not work. I get vibrations closing and opening Game Vibe. When you start vibrations Game Vibe works well and is very easy to use.
  3. L.Dörenberg
    L.Dörenberg beginner Gold Contributor
    car bodyrepair
    Netherlands
    - 65Coins
    hi there, simtools says that i have to restart simtools game engine when im running Pc2. this problem occured after the patch 5.0, i hope someone can help me. thanx.
    greeting leroy
  4. yobuddy
    51,747Coins
    The only reason I can think of for this, is if a SCN / Hyperaxis was not able to center (Initialize)correctly on Game Engine Startup.
  5. L.Dörenberg
    car bodyrepair
    Netherlands
    - 65Coins
    You were right! :D 1 actuator was not connected well. Thanx again buddy!
    Leroy
  6. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,384Coins
    Hi, I have a question, I used the plugin, seems to work correctly.
    But in my case, I have a 360 yaw system. The current Yaw implementation is not suited for my system. Is there a way to add an extra2 or something to have a YAW working for my situation ?
    Thanks for the time and effort.
  7. yobuddy
    51,747Coins
    @Wagnard
    For a 360 yaw simulator, please try this.
    First the pot connected to the Yaw setup needs to be disconnected from the yaw motor and centered.
    That's right, disconnected and centered.
    To find perfect center, startup SimTools and click output testing (but do not move anything)
    You should find you can spin your simulator by moving the yaw pot back and forth from center.
    Make sure it is centered and not moving and stop the output testing.
    Now what you want to do is to assign Traction Loss to the yaw axis with No washout.
    You should find that when you turn a corner, your sim spins also.
    And when you spin out, your sim does also.
    (add a touch of Dead Zone, and you can stop it spinning when turning and only react to slide outs, if you want)
    You can probably drive this setup with Yaw + Washout also, but results may very.
    So i would try traction loss fist.
    take care,
  8. Wagnard
    Wagnardsoft
    5,384Coins
    Thanks for your time answering , it's appreciated.
    My simulator is already configured as you said. Pot disconnected and centered. Xplane 11 already work very fine with that kind of yaw.
    I only did small testing with the "traction lost" and sometime it seemed to work as I wanted and sometime not. Maybe i'm just not understanding exactly what traction lost mean.
    What I wanted is simply a yaw making my motion simulator turn left or right as the car turn in the game.
    So technically , all I want is turning. no slide outs.
    But i'll give it another shot and play with the dead zone and ill check the washout stuff.
    Thank again
  9. KonikAV
    KonikAV New Member
    343Coins
    I have two questions:
    1. Is it possible to add pCars2 Demo to the plug-in?
    2. In the case where the car rests against an obstacle (such as a fence) and can not leave, the simulator randomly twitches - throws the player. Is it possible to smooth out these throws without affecting the rest of the impacts?
  10. baxbax
    baxbax New Member
    135Coins
    Great work!!
  11. Wagnard
    Wagnardsoft
    5,384Coins
    Hi again,
    I would like to know if I can politely ask for the code of the plugin for
    1- educating myself on how this one was done (currently tried to make one but some what stuck)
    2- I want to change a value from the original one I'm interested in the "mAngularVelocity" for my yaw.
    Great work again and do not feel forced to share the code with me if you prefer not, I would understand.
    Regards,
    Edit: I was able to do it finally , combining existing C# code and the example from racer plugin.
  12. yobuddy
    51,747Coins
    Nothing in simtools ever askes you to install any plugins?
    Got a screen shot maybe?
    take care,
  13. yobuddy
    51,747Coins
    @Wagnard
    Nice work buddy!
    The first one is always the hardest!
    Take care,
  14. yobuddy
    51,747Coins
    It's telling you the AC plugin you have installed is not valid.
    Download and install the newest AC plugin and you should be good to go!
    Take care,
  15. yobuddy
    51,747Coins
    Please goto: "C:\Users\(your user name)\AppData\Local\SimTools\GameManager\GameProfiles"
    Please zip this folder and send it to me buddy.
    I will see what's happening...
  16. yobuddy
    51,747Coins
    Please goto:
    "C:\Users\(your user name)\AppData\Local\SimTools\GameManager\GameProfiles\Profiles\pCARS2"
    Please delete the file "pCARS2_Default.pro" and then restart GameManger and you should be all fixed!
    btw, I think this bug is fixed in the next release!
  17. SEHATanguy
    SEHATanguy Member
    Belgium
    96Coins
    Hey guys, there are a lot of plugins for P Cars 2, could you tell me which one is the best?
  18. themickael
    themickael New Member
    FRANCE
    91Coins
    Hi, How can i download this plugin ? please
  19. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    Buy 250 + points or participate on foruns until reach 250 points.
  20. paulopsx2
    brasil
    649Coins
    Not " a lot plugins"... only udp for videogames ( or pc if you choose ) and last version for pc.
