PICMICRO 16F887 --18f2550 USB virtual Comm--
Discussion in 'SimTools compatible interfaces' started by kubing, Oct 20, 2010.
  1. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Re: PICMICRO 16F887
    [img600px]http://3.bp.blogspot.com/-HyA65-a6crU/TZSYzxPLsBI/AAAAAAAAARc/Qdj2JnXzJ6U/s1600/2dof.jpg[/img600px]
    After a month of testing and tuning on my inverted pendulum buggy I have found that by adding suppression caps to the POTs will drastically reduce the noise problem. This update applicable to all pots in my schematic. But only VR1 and VR2 shown. :thbup:
    [img600px]http://2.bp.blogspot.com/-b945LTGmRak/TZU7QpYxeRI/AAAAAAAAARg/OMg9H3bE9lA/s1600/31032011767.jpg[/img600px]
  2. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Re: PICMICRO 16F887
    update with fully adjustable PID display on LCD.
    x-sim-->uart_read--->pid protocol-->pwm_out_---> lcd display or graphical TFT LCD with real time graph...time to migrate to more powerful core i think :?
    http://www.youtube.com/watch?v=CbGPBpwLriM
  3. ferslash
    ferslash Active Member
    4,798Coins
    Re: PICMICRO 16F887 (update 16F1937 32Mhz now)
    Dear Kubing:
    for months i have looking at x-sim traing to find if someone did what you just achieved in your blog, using components ready to use, in order to avoid constructing the thanos technology.
    Since i don't know anything about electronics, but i can follow instructions :D and i really whant to construct a simulator.
    i have then, two questions for you, hopping you can answer:
    1. is your work finish, so i can just follow your instructions in your blog??? (www.simf1.com)
    2. i saw you constructed a flex kind of simmulator, i would like to construct a joyrider style (like the one thanos made), can i use your job and just construct a different simmulator or the joyrider needs a whole different set of programing and electronics stuff?
    3. (i a new one) talking about the electronics, how much did you invested creating your pice of art?
    a fan from mexico
    Fer
  4. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Thank you for your interest and follow my blog.
    1) yes i have finish my work with full PID control.
    2) I built this cockpit in frex style only since it was design for F1 and not suitable for Flight sim. You can modify your x-sim profile for joyride if you want. I never tried.
    3) this is prototype and I need so many difference equipment to built, test, burn and of course its very expensive. Once its ready and done its very cheap to re'built'. You can built this below than USD350.
    Regard
    Kubing
  5. estanislaolopez
    estanislaolopez Member
    Argentina
    80Coins
    2DOF, DC motor, SimforceGT
    Hi ,Kubing, I have long followed your project is great !! I have built my simulator with the AMC by Thanos and works very well, but I would like to build your board based on Pic, but I do not have a development kit, could be programmed with a homemade pic programmer? if so could you provide me the hex file ?
    Greetings and I follow the blog :thbup:
  6. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Thanks, I use ICD3 for programming. pic16f1937 may not work with DIY programmer. you can try but I'm not sure. pickit3 is a minimal investment if you love PICs project. development board are not necessary but if you plan to buy I recommend olimex with ftdi chip on board. at the moment I'm on vacation. will upload hex later as you wish. :D
  7. estanislaolopez
    Argentina
    80Coins
    Thanks Kubing , I'll study the possibility of buying a developer ...
    Enjoy your vacation
    Regards
  8. willynovi
    willynovi Member
    Argentina
    354Coins
    hi kubing, did you think using 18F2455 family, 18F4550 could work very well as it has USB conection, just think about it ;)
  9. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    I'm away from my simulator right now...built this since last year..it works great on terminal application.I use 18f2550 cdc..but x-sim cannot detect this virtual comport...not sure why. forgot about this since i'm buzy with kalman and PID implementation. thank you for remind me back to my historic project. :D
  10. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    I am back!!. I have take out my pic18F2550 and finish my undone USB work about 3days...all fix and code done.. will follow with schematic..very busy now. you can check my first attempt to setup USB CDC..good bye FTDI and Maxim232...the circuit are damn simple..only 4 caps used. 2 resistor and LEDs (if you like).
  11. RaceRay
    23,892Coins
    Wow, looks really promising.
    I keep watching your thread :)
  12. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Hi all, Thank you guys for your moral support. After almost one year starting this topic, finally its come to a reality. FULL PID with USB virtual comm. all harness, cost and complexity of usart -TTL circuit are now simplified into the MICROCHIP brain. After mass modification of original code for 16f1937 about 4 days..seems like i am going to sleep for a week after posting this. Any comment are welcome.
    Regard
    Kubing
    Kelantan, Malaysia.
  13. estanislaolopez
    Argentina
    80Coins
    Very well, this pic can be programmed with a programmer diy jdm type is a simple board with few components ... Congratulations, I follow your progress through your blog !!
    Regards
  14. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    you can breadboarded it fisrt and put some leds for pwm and motor direction to make sure its work in your machine. code uploaded. :D
  15. willynovi
    willynovi Member
    Argentina
    354Coins
    I built this one :yes:
    http://perso.wanadoo.es/pictob/jdm.htm
    but it needs a serial com port, it doesn´t work with usb adaptors :(
    I work a lot with 18f2550, if you have any doubt just ask, maybe I can help you
  16. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    any feed back are welcome. any picture of construction relate to my board can be publish here.I have built david tait programmer long time a go and never tried JDM before.. D. Tait work for me and he use parallel port. but any cheap usb programmer from ebay would be nice option for complete beginner.
  17. dj dicksy
    dj dicksy New Member
    Romania/Bacau
    340Coins
  18. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    great link. keep it coming.. :hi:
  19. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    driver update..readme first
  20. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    video for my controller..just on strip board. working great. red led show usb connection established. blinking blue led for incoming data.,it can be use to make sure x-sim is sending the data or not.
    http://www.youtube.com/watch?v=uJY9fQaZO2Y
