PICMICRO 16F887 --18f2550 USB virtual Comm--
Discussion in 'SimTools compatible interfaces' started by kubing, Oct 20, 2010.
  1. estanislaolopez
    estanislaolopez Member
    Argentina
    80Coins
    2DOF, DC motor, SimforceGT
    Hi Kubing , good progress !!! ... when I have time will try to assemble the pcb with the pic2550 to test it in my simu ...
    Regards
  2. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    [img600px]http://1.bp.blogspot.com/-3UsdJzPNp0g/Tr6c3SfqdII/AAAAAAAAAhk/4-8A7CURDdY/s1600/DSC01750.JPG[/img600px]
    [img600px]http://4.bp.blogspot.com/-1x-veD6VE50/Tr6dZELrldI/AAAAAAAAAh0/YsU4fY_CFJg/s1600/DSC01752.JPG[/img600px]
  3. jony
    jony New Member
    Hi, kubing!
    How can I get a HEX-file for PIC18F2550?
    Is there an open source project for the 16F887 or 18F2550?
  4. jony
    jony New Member
    Hi!
    There are still questions.
    Why on board three variables resistor?
    How to connect to the controller two variable resistors (sensors with motor shaft). As these sensors are connected? When lifting platform, the sensor should go more or less volts?
    What resistor values?
    Who can answer these questions. I would be grateful.
    Thank you.
  5. xenocide702
    xenocide702 New Member
    - 10Coins
    I am not certain, but I can guess that the three potentiometers are for tweaking the PID gains (kp, ki, and kd respectively). As for your question about the open source project, are you asking for an IDE? I've been using mplab without issue with my PIC18F4550 projects. If you mean his source code I can't speak for him, but it'd probably be worth sending him a PM.
  6. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    after 544 downloaded from version 1.1 since last year. No one come up with any respond. I consider the code is not working on other machine.
  7. yobuddy
    51,703Coins
    Love the project kubing! :cheers:
    Anyway you could post a build of materials and a hex file?
    Do you happen to have a PCB layout so others and I can make the board?
    Do you know if I can use Tronicgr’s analog converter to get a 0 – 10v analog output?
    I want to play with some big AC stuff 8)
    http://www.x-simulator.de/forum/tro...er-with-pwm-servo-output-t559-620.html#p14488
    Anyway – I sure appreciate you hard work.
    Can you tell us any details of the BuduFSX controller?
    Thanks Allot!
  8. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    This is just a part of my hobby. Its really fun. I really need to confirm this code is working on others thats all. Its not worth to invest your money and time on something not working. please invest your money on tested and proved project by many. thank you. :)
  9. yobuddy
    51,703Coins
    I do all this for fun too!
    I already have a working scn5 simulator.
    I have built Tronic’s AMC and the DSMhb, I have even built 2 Rock’n’Ride controllers – lol
    I really believe a simple to build controller will really help the community along!
    Just like the one you have built!
    Need testing? – That’s what we are here for :cheers:
    Anyway, please think about letting some people test the controller, It realty Looks Great!
  10. bsft
    Well you have my attention, I run the pololu jrk for simplicity, as the tronic card looked difficult with producing circuit boards and sourcing parts.
    The Arduino has code issues but potential.
    If you guys are developing a board that could run either 12v at say 50amps and or 24 volts at 30amps, I would be interested in trialing one. I am code illiterate so that would have to be sorted first, or at least a base line I could figure out.
    PM me if you wish to talk further about it, I will donate towards the cost.
    Cheers, David.
  11. estanislaolopez
    Argentina
    80Coins
    Hi Kubing , I have not had time to test your firmware on pic2550, I'll do a test with the circuit and the Hbridge by Tronicgr, on this holiday ...
    Regards
    Pablo
  12. swserikoff
    swserikoff New Member
    Hi, kubing!
    Can I get a HEX-file for PIC18F2550 2dof too ? I am testing it and writing you about result. Thank you for your work.
  13. sebamaz
    sebamaz New Member
    Hi, I'm new to the forum, I would like to build this simulator, the controller with PIC 18F2550. I need to know where to download firmware and circuit schematic. my e mail sebamazzieri@hotmail.com
    Thank you.
  14. yobuddy
    51,703Coins
    Any news?
    How did the testing go?
  15. sebamaz
    sebamaz New Member
    Hi, I'm building a controller with an ATMEGA 8535, I wish I could do it with a PIC because I know more and Argentina are easier to obtain. I want to pass information to build the controller with PIC 18F2550.
    greetings and thanks
  16. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    very busy right now. I lost my own thread btw :D. Budu 2dof v1.5 is about to release. tested working great on win7 64 bit and vista 32.
  17. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Good News :clap:
    year to, hard work, thanks。
  18. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Budu 2dof v1.5 uploaded.
  19. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Next generation sim for my controller. to be design with VFD compatible in mind . hopefully to be compatible with yaskawa, siemens and mitsubishi motor driver.
