[PIMAX] All about the VR headsets
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Pit, Sep 19, 2017.
  1. born2bslow
    born2bslow Member Gold Contributor
    272Coins
    3DOF, Motion platform
    The 4K was the equivalent of the Dk1/2 for Oculus and wasn’t a mass produced unit. They are effectively a new startup building infrastructure as they go.
  2. SeatTime
    Received my new replacement cable from Pimax today. Have been running it for over a Hr and it has fixed the 'sparkle' issue completely :). Happy customer.
  3. anton_Chez
    anton_Chez Member
    445Coins
    Good to hear :)
    Is anyone doing anything about motion compensation? I've got a base station now and was wondering if it was worth exploring. I'm going to test my Rift again to see if there is any noticeable difference with tracking. Now that I have 3DOF motion, the heave can be quite brutal on the viewpoint. Even with full tracking and a pretty good fit on my face. I need to do more testing and maybe tune the heave to work better with motion. I never had a problem on my NLR V3 seat mover and I have limited experience with my Rift in the new motion platform. I don't have access to trackers or controllers so I would have to invest further if I were to pursue it.
    I wonder how much you can avoid the HMD bouncing slightly on your head on bumpy tracks, even WITH motion compensation?
  4. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
    Mine is boxed up for the long trip back to China. They want to inspect it to see why I’m getting such bad warping and eye strain. They said they will replace it if it’s faulty or else offer me a refund. I’m also told I have to pay for shipping to China (€80) and that I will be reimbursed! I’m hoping for a full refund as I don’t believe they can deliver a quality product.
    The Pimax housing developed two hairline cracks at a corner and now the bit between the cracks has fallen away. It has never received any knocks. I never got the promised cable replacement. So far the entire experience has been a big let down.
  5. born2bslow
    272Coins
    Demand an rma for the cracking as it’s a common issue. My rma after a teamviewer session with them advising the hardware problem was turned around in 12 days and I only paid for the return to the uk warehouse. They refunded that the day after I uploaded the receipt.
  6. anton_Chez
    anton_Chez Member
    445Coins
    I believe the eye strain is caused by a combination of incorrect / inability to set correct IPD and also a low frame rate. I killed my eyes testing out resolution settings that were too low in hz (50 -55, no smoothing) and was wondering how I was so sore after a short time. Another forum member suggested the low hz was an issue and that's one of the only times I've ran it that low for longer than like 5 minutes. I went back and fixed that up and I was able to drive so much more comfortable, like all the times before. I still am getting used to the fit and I think it's a little tight still because I use motion, but I have some new face cushions coming Monday so I will try to readjust the strap when they get here.
    Many users have reported the eye strain issue but I think there are a few things at play here.
  7. SeatTime
    Mine looks fine.. although they have made the plastic thicker in later models.
  8. anton_Chez
    anton_Chez Member
    445Coins
    Yeah I think mine is labelled P2 or something? Something 2 anyway, showing the newer release.
  9. SeatTime
    Yes, there is a video I linked to later back in this thread, 'Model:2' . They fixed a few things.
  10. RiftFlyer
    1,711Coins
    DC motor
    model P2 has nothing to do with the cracking issue. Mine is p2 and still cracked. It’s obvious that the sharp angles are resulting in stress risers.
    I don’t think it’s any coincidence they have just announced an upgraded ruggedized version. The current one is bound to fail.
  11. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    I agree with you that there are many things at play here: framerate, HMD position on the face, brightness level, IPD setting, PP compatibility mode, smoothing. I also noticed strange thing - yesterday I tried to pay close attention to how image looks and at what angle etc, my eyes got tired. But today I just relaxed my eyes and was focusing on racing itself, and noticed no issues whatsoever. Spent like 3 hrs driving.
  12. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    I have finally managed to get my headset working. I am currently only using it to play Assetto Corsa but when using the headset it is displaying the image on my screens as well as the Pimax display. How do I stop it displaying on the screens and overloading my video card?
  13. anton_Chez
    anton_Chez Member
    445Coins
    There is an option in SteamVR that says 'show VR on screen' or something like that. Uncheck that. It should be off by default though. Also, AC might have this built in by default so you might have to dig into the ini file and disable 'mirror texture' or something like that.
  14. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    Update on the Pimax8kx specs, including a one cable solution, it is 75hz but they hope to push that to 80hz, using low persistence RGB panels with higher panel utilisation, all of which should be of interest to @SeatTime:
  15. marco balletta
    marco balletta Member
    1,445Coins
    I am a backer of the 8kx
    Too bad that for now it is just a 75hz headset
  16. SeatTime
    Yes, I'm a backer of the X. Honestly thought this was never going to happen, should be interesting :).
  17. marco balletta
    1,445Coins
    75hz for car simulator usage, worries me
    I wish pimax would have gone to full human sight fov with the pimax 8k X
  18. Pit
    30,510Coins
    Im on the Pimax 5k+, large FOV and 72 Hz, it is super smooth, fluid, nothing to complain about the reduced 72hz (instead of 90hz, no difference imho).
  19. marco balletta
    1,445Coins
    Lucky u.
    I get motion sickness using the 8k and not even using my rig, but just driving in vr with the 8k, using a keyboard or the wheel, with no moving chair
  20. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    3DOF, DC motor, Arduino, 6DOF
    Using the Pimax in a race game WITHOUT a motion rig is the best way to get motion sickness.
    I guess you don't feel better with your rig activated?
