Pneumatic G-seat project.
Discussion in 'DIY Motion Simulator Projects' started by T R Para, Feb 17, 2020.
  1. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    Hey @SeatTime yes they unfortunately are non linear, bang on/bang off...
    It seems the electrically operated linear air valves are about $1K a piece and those were used ones.
    Some quasi linearity actually exists with the GameEngines output.
    Very short peaks of duration never fully fills the bladders but many short bursts in a row will. My control board has the ability to adjust at what amplitude/threshold of the GameEngine the air solenoid fires at.
    The fill time on a full bladder is well under 1 second.
    which reminds me of my own bladder seeming to fill at all hours of the night !..
    so there is a small bit of linearity there...
    I did acquire several one way flow controllers that may possible be able to be incorporated but they are screw actuated adjustments and not easily incorporated..
  2. Sijmen
    Sijmen New Member
    131Coins
  3. BlazinH
    16,699Coins
    That's the concept my Jiffy G-seat uses as well. Not only faster inflate/deflate but also more stable compression. And if you look at them in terms of being an actuator you can also give them more range. The Jiffy G-seat for example uses in excess of 30 air bladders.
  4. RacingMat
    21,088Coins
    you've made nice progress! thanks for sharing :)
    keep going
