Presentation functional version 2DOF arduino and IBT2h
Discussion in 'Ready, set, go - Start your engines' started by Luis Arnaldo Ribeiro, Nov 3, 2018.
  1. yondwangmms
    yondwangmms Member
    - 148Coins
    Parallel connection of two IBT2 and good heat dissipation are a condition to ensure stable operation of IBT2. My test is that a single IBT2 under the original heat dissipation conditions cannot drive a 24v 250w DC motor to work continuously.
  2. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    in theory they should have power to dissipate 500w 250w @ 24v they should be within the Safety operation Area of their datasheet.
    here something does not return with the electrical connections.
    I repeat, I had the brushes shorted (flying motor) for distraction assembly after revision, the ibt whistled, the cables heated like crazy, and I did not immediately understand what was happening. but nothing of them, even with a short circuit (only the resistance of the cable 25mmq x 2 + 2mt) did not burn.
    for me they are very robust, thin the product is born defective this is possible.
    good continuation
  3. Ricardo Soares
    Ricardo Soares New Member
    83Coins
    Good afternoon Arnaldo.No Arduino Uno need to record a Sketch? Or am I talking nonsense if yes you could make it available?
    153,764Coins
    +11,149 / 57 / -2
