Showroom pressoff's 2dof
Discussion in 'DIY Motion Simulator Projects' started by pressoff, Jan 11, 2014.
  1. eaorobbie
    20,505Coins
    Let me second that , Thank you heaps mate.
    How are your electronics going, nearly ready to test motors.
    Keep up the top work.
  2. pressoff
    pressoff Member
    Russia, Saint-Petersburg
    1,004Coins
    trying to connect the potentiometers and test on small engines
  3. ferslash
    ferslash Active Member
    4,798Coins
    woow impressive!!! how much did you spend in materials building the seat??
    are you planning to add some tipy of cussion to the seat?
    what caliber was the iron board you used?
    woooow nice nice work
    best regards
    fer
  4. pressoff
    pressoff Member
    1,004Coins
    materials are not considered.
    iron 1 mm.better use of aluminum 2-3 mm
  5. pressoff
    pressoff Member
    1,004Coins
    it is impossible to organize communication on bluetooth ((((anyone encountered this problem?
  6. eaorobbie
    20,505Coins
    SimTools has not be designed to use bluetooth, Sorry. Use either the comports(usb) or udp over the network if your controller allows.
  7. pressoff
    pressoff Member
    1,004Coins
    so what's the difference, use the com port or Bluetooth com port usb?
  8. eaorobbie
    20,505Coins
    ?Bluetooth might be a usb device but its not the same as a comport.
    If you can provide some details on it, we might be able to have a look, no one asked in the beta testing about possible Bluetooth compatibility so it wasn't looked into sorry.
