Question Preventing motor drivers from burning up from reverse curreng (regenerative breaking?)
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Ronan Design, Oct 16, 2024.
  1. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,322Coins
    You can place the fuse as you described.
  2. Aerosmith
    Aerosmith Active Member
    self employed
    2,778Coins
    3DOF, AC motor
    Electrically, it doesn't matter. In a series connection the circuit is interrupted when the fuse blows, no mater if it's placed before or after the rectifier. The reason behind the rule "as close a s possible to the power source" is that the fuse also protects the cables after the fuse. That would be useful if those cables are moving or can be damaged by moving parts.
  3. Mariano Tarnogol
    Mariano Tarnogol New Member
    335Coins
    A bit off topic. Im going to switch my 3x ibt2 to cytron md13s.
    Mode 1 in smc3 without modifications works well?
    In your connection diagram i can see you wired the NC pin on cytron boards to a digital pin on arduino. Dofreality leave it unused. Can you explain why?
    Thanks!
  4. Ronan Design
    Toronto, Canada
    1,721Coins
    Yes, mode 1 works. I wired it this way because I found the pinout somewhere on this site. It makes sense, SMC3 has 3 pins used (ENA, ENB, PWN) plus ground. I can't explain why DOFReality doesn't use it...
  5. Mariano Tarnogol
    335Coins
    Found that pdf showing wiring. Just want to be sure.
    As for dofreality, they even use encoders and motor brakes, i think they made massive changes on the original smc3 software.
