Resolved Problem Simtool 1.3 not working offline
Discussion in 'SimTools DIY Version' started by Icefox, Mar 9, 2016.
  1. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    3DOF, Arduino, SimforceGT, Motion platform
    maybe the problem with the plugin of dirt 3 does not connect to your sim tool game manager..try to do step by step for solve that problem..
  2. BlazinH
    16,698Coins
    If you’re using the original Dirt3 CD or a crack then at minimum you must set up an offline GFWL account in order to use it. But that not the issue it seems, only telemetry. You can get it from Steam now as mentioned without GFWL but since its Steam you still need internet access at least every now and then. But the issue is he said he won’t have internet access where he plans on setting up his rig.
  3. Icefox
    Icefox Member
    549Coins
    thank you all !
    Hi noorbeast did you proceed in the following sequence :
    1.) computer off and ethernet cable disconnect
    2.) start computer
    3.) launch simtool and the game
    Caution is misleading if the computer is already running simtool will work without ethernet cable ( In my case )
    Window 7 is 64bits, the patch is ok.
    We can exclude a problem with dirt 3 because i tested with the LFS games and the result is the same :-/
    If you can confirm that with the manipulation above it works the problem would come from my computer
    I live in a building with no room in my home to play
    I instaler the simulator in my basement and it will be impossible to have access to the internet that is why I would like to solve the problem.
    I'm surprised to be the only one with this problem but on the other hand I think that all the players on internet access..
  4. rattler
    rattler
    Yes but when it was GFWL, you could create an offline account so you could save your game progress and run offline. Ive run both cracked and genuine versions of Dirt3 and now I run it on steam. And thats on windows 7 32 bit and 64 bit PC.
    All I need now is a motion ride.
  5. Historiker
    Michigan USA
    9,205Coins
    Actually, I used to run my sim out in my shop which did not have internet access. Motion worked fine with Dirt3.
  6. Icefox
    Icefox Member
    549Coins
    Thank you for your return, so i can blame my computer.
    it remains to find the solution :-/
    154,418Coins
    +11,181 / 57 / -2
    Mine is wireless but it works fine if that is turned off.
    That is exactly what I meant about about Googling the tools to get around the CD and connection restrictions
  8. Icefox
    Icefox Member
    549Coins
    ok thank you for help, I'll try to find the reason for my problem.
  9. Icefox
    Icefox Member
    549Coins
    Problem resolved with creating a network loopback adapter.
    thank you
  10. rattler
    rattler
    Well done. Good to see its sorted.
