value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. lcturkey
    lcturkey Member
    163Coins
    I will try it will udp version plugin and let you know I hope it will work there. Do I need a network connection for that ? I am using it on PC
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,059Coins
    Arduino, 4DOF
    UDP is likely to be less impacted by new patches/releases. Let me know if it works. If pcars and xsim are on the same PC, no specific network settings, just activate UDP. Pcars then send UDP using broadcast.
  3. lcturkey
    lcturkey Member
    163Coins
    I will try it tonight and let you know. all of them on the same computer
  4. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    2DOF, DC motor, JRK, SimforceGT
    Have you checked if the plugin worked Icturkey?
  5. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    I have my motion connected to a #2 pc.
    Anyone knows if the alternative plugin works with Oculus and motion in UDP mode then?
    Anyone tried that? :)
    Or does UDP only work when game manager and game engine is on the same computer?
    I may better be prepared to when I receive Oculus :)
  6. lcturkey
    lcturkey Member
    163Coins
    Yes udp pluging is working
  7. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Thanks.. Great ;)
  8. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    333Coins
    Not sure if this is a plug-in issue or not, but my windsimulator works fine in practice modes with only one car, but as soon as i start a race with AI it doesn't work at all anymore.
    Simdash produces an error: "session state" invalid.
  9. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Does anyone knows why my gamedash only work in training mode? It stops working in a single race mode. The events seems to be INVALID. Does anyone know a fix for that? tks!
  10. HoiHman
    Mechanic
    The Netherlands
    333Coins
    You're having exactly the same issue as me mate. It seems like nobody knows how fix it or just don't car about pcars anymore, since there have been no replies on my post from almost a month ago.:(
    I have been testing and trying things out and i have narrowed it down to a profile related issue. Yesterday when i tested my windsimulator, magically gamedash worked in the single race mode. I immediately tried a race in the career and this also worked. Here the strange part: I didn't change a thing to get it to work. After a couple hours of racing, suddenly in the career mode i got the "session state" INVALID again and my wind simulator didn't work anymore in the careermode. :confused:
    It still worked in the single player mode. At that time i made a backup of my pcars save game located in F:\steam\userdata\******\234630\local\project cars\profiles folder.
    After playing some races in the single player mode, the windsimulator did not start. When i checked gamedash started to give the "session state" INVALID again.
    When i replaced the default.sav in the F:\steam\userdata\******\234630\local\project cars\profiles folder with the one i backed up before it started to work again, but only in the singleplayer quick races. It really bugs me a lot, because i was just about to dive into the massive single player campaign. So this morning i uninstalled Pcars, deleted all my config files (in mydocuments) and the entire steam pcars profile folder. With a fresh installed pcars and shared memory enabled: IT DID NOT WORK :mad:
    When i put the backedup profile in the profiles folder overwriting the one from the fresh install, simdash worked again. But only in single player races.
    Does anybody have any clue how to fix this or could someone who has gamedash working in the careerraces please upload the savegame so i could try if that might fix my problem.
  11. value1
    14,294Coins
    To be honest, I never bothered too much about debugging the GameDash data. I'll check, if there can be something improved in the plugin.
  12. HoiHman
    Mechanic
    The Netherlands
    333Coins
    Thanks a lot that would be awesome:thumbs
  13. HoiHman
    Mechanic
    The Netherlands
    333Coins
    I have been testing and i have found that a low number of laps is the cause why simdash is not working .
    As it turns out simdash needs a minimum of 9 laps in order to work.
    If you choose either a quick or career race that has less than 9 laps in the race session, simdash will produce the "session state INVALID" and will not receive or output any data.
    It's not distance, but pure lap related. For a race on the nords you also need at least 9 laps in order to make simdash work. This also means that california highway and azure coast both do not work with simdash.
    I hope this helps debugging
  14. HoiHman
    Mechanic
    The Netherlands
    333Coins
    I did some further testing and I have narrowed the window down in which simdash works.
    It's 9 - 13 laps
    If you start a race with more or less laps, simdash will see the Session State as INVALID
  15. value1
    14,294Coins
    Please check this plugin and let me know, if it works fine. Thanks!
    pCARS_Plugin.zip
  16. HoiHman
    Mechanic
    The Netherlands
    333Coins
    Thanks for looking at the problem.
    I just updated the plug-in and repatched the game and it didn't work. With the updated plug-in simdash does not receive any data from the game. All dashes (including the sessionstate) remain at zero.
  17. HoiHman
    Mechanic
    The Netherlands
    333Coins
    @value1, i also found out that setting racelength at 100% also works.
    Did you have time to further investigate this problem?
  18. HoiHman
    Mechanic
    The Netherlands
    333Coins
    So what are the chances of this plugin ever gets updated so that the sessionstate invalid problem is fixed?
    • Optimistic Optimistic x 1
  19. noorbeast
    154,675Coins
    +11,209 / 57 / -2
    All of the focus and effort is on developing plugins for the release of SimTools 2.0, with over 50 already prepared: https://www.xsimulator.net/communit...-question-and-answer.8175/page-13#post-117345
    Current plugin will soon be irrelevant and redundant. The wait for SimTools 2.0 will be worth it, it has performance improvements that make you rig feel like it got an upgrade.
  20. vthinsel
    FRANCE
    6,059Coins
    Arduino, 4DOF
    Hi !
    Just got my SimTools 2.0 license and got the plugins. One thing coming to me: is this new plugin a UDP one ? It mentions port 4123 but also processes, but I do not the the start button in the profile editor / main section.
    Beside this, do you know when the plugin templates (UDP mainly) will be on-line ? so I can port my UDP plugins :p
    Thanks for your great work !
    EDIT: obviously it doesnt use UDP as the plugin works with UDP set to off. I also confirm the plugin works with the free Pagani Edition available on Steam.
