value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    This plugin just stopped working for me this morning. Anyone else confirm a patch or something broke motion? Will update if I figure it out...
  2. stamer57
    stamer57 Member
    963Coins
    Not for me. The plugin still working with the new patch of Pcars.
  3. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Me too, it's still working with the old plugin. No problem :thumbs
  4. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    Is this compatible with 1.3? I get motion in virtual axis but no rig movement just when I hit a wall it moves a little. LFS is OK with same setup.
    EDIT: I found what did it. Had to change minmax
  5. matrixpascal
    matrixpascal Member
    305Coins
    Hello.
    I can not run my emulator with pcars plugins.
    I have pcars of steam.
    when I select the direction for patching the game it tells me that this is not the right play.
    I try with the plugin pcars 2 and it's the same.
  6. value1
    14,296Coins
  7. matrixpascal
    matrixpascal Member
    305Coins
    Thank you.
    but I have already had the information elsewhere
  8. MotorSport
    MotorSport New Member
    - 137Coins
    3DOF, Arduino
    Ce plugins sert à quoi exactement (c'est un reglage preci des axe ?)
    154,711Coins
    +11,212 / 57 / -2
    Google translate - This plugin is exactly what (it is a preci setup of axis?)
    By all means post in your native language @MotorSport but please do also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language group so if Google Translate really messes it up they can help clarify what was intended.
    There is a specific section for native language based social interactions: http://www.xsimulator.net/community/#international-social-chats-and-conversations.155
    The plugin allows the SimTools to utilise data from the game, which is extracted by various means: http://www.xsimulator.net/community...a-plugin-for-simtools-api-documentation.4612/
  10. bsft
    @moaale , it looks like you have enough coins top get yourself a weekly download pack for the plugins you want.....
    154,711Coins
    +11,212 / 57 / -2
  12. nicodu74
    nicodu74 New Member
    france
    294Coins
    Hi for traction loss what is the best set up , if have put my third
  13. nicodu74
    nicodu74 New Member
    france
    294Coins
    actuator on axis 3 and extra 1 but it doesn't work !!! Can you help me ...
  14. nicodu74
    nicodu74 New Member
    france
    294Coins
    I found the solution myself , i make a mistake on setup !!! when the set up is right i post my setup ;
  15. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,059Coins
    Arduino, 4DOF
  16. bsft
    Lucky you, game dash crashed as soon as I start project cars game
  17. vthinsel
    FRANCE
    6,059Coins
    Arduino, 4DOF
    Guys, I missed a major announcement around Project Cars some week ago : UDP telemetry output, even on next-gen consoles !!!!! Yiiippppeeeee !!!!!!
    http://forum.projectcarsgame.com/showthread.php?40113-COMPLETE-Companion-app-UDP-streaming
    This includes dashboard data as well.
    Based on the UDP spec, who is likely to make a plugin ? This approach is a bit the same as "The Crew".
    If you want a guinea-pig for PS4 testing on PCars, I'm in (when patch 7 goes on PSN) !
    For PC, it is included in patch 6.1 : http://forum.projectcarsgame.com/showthread.php?42188-Project-CARS-PC-Patch-6-1-Release-Notes
  18. vthinsel
    FRANCE
    6,059Coins
    Arduino, 4DOF
    After following the plugin tutorial which is brilliant, there is still something I do not catch : where do we specify the UDP packet structure we are expected to receive ?
    Pcars UDP packet structure is (extract) :
    f32 sOrientation[3]; // 136
    f32 sLocalVelocity[3]; // 148
    f32 sWorldVelocity[3]; // 160
    f32 sAngularVelocity[3]; // 172
    f32 sLocalAcceleration[3]; // 184
    f32 sWorldAcceleration[3]; // 196
    f32 sExtentsCentre[3]; // 208
    This is the same as the shared memory structure (usefull to get the units used)
    // Motion & Device Related
    float mOrientation[VEC_MAX]; // [ UNITS = Euler Angles ]
    float mLocalVelocity[VEC_MAX]; // [ UNITS = Metres per-second ]
    float mWorldVelocity[VEC_MAX]; // [ UNITS = Metres per-second ]
    float mAngularVelocity[VEC_MAX]; // [ UNITS = Radians per-second ]
    float mLocalAcceleration[VEC_MAX]; // [ UNITS = Metres per-second ]
    float mWorldAcceleration[VEC_MAX]; // [ UNITS = Metres per-second ]
    float mExtentsCentre[VEC_MAX]; // [ UNITS = Local Space X Y Z ]
    So basically we have everything we need in the packet to get roll/pitch/yaw/heave/sway/surge
    I just need to find the "dissector" part in order to fill-in the MyOutsim_Internal var or OutSim upon UDP packet received.
    Any hint on how/where UDP incoming packet is processed ? Should I rewrite completely a Process_PacketRecieved function ? I'm not a valuable VB guy; more C on Arduino :roll
  19. noorbeast
    154,711Coins
    +11,212 / 57 / -2
  20. vthinsel
    FRANCE
    6,059Coins
    Arduino, 4DOF
    Thanks. I already included them in a conversation :p
    I must admit I'm quite excited with what's going on with this topic, so I'm a bit like a little impatient child:D
