value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,059Coins
    Arduino, 4DOF
    As explained earlier the current plugin is PC only. I love to play on PS4. It also allows apps on tablets/softphones to get data directly from the game without needing a specific app on a PC.
    Moreover, the current plugin doesn't seem to support gamedash in all modes. Mine does.
    And it's fun to get your hands on the plugin dev :D
  2. SilentChill
    20,660Coins
    Ah cool @vthinsel I should of read the rest of your posts :) Wish I could get my head around it good luck with it
  3. piorck
    piorck Member
    french
    258Coins
    hello , my plugin and the communication to simtools have a problem ;
    since this morning when i'll run pcars with game manager , i'll see this message :
    pcars shared memory version mismatch .
    what the probleme?
    i'll turn mms on to pcars .
  4. eightbit
    eightbit Active Member Gold Contributor
    Fish Farmer
    Trentham Cliffs
    183Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Thank you very much value1! I can't wait to try it out on my scale model 6D. By the way do you know if anyone is working on a rpm output of some description as I would love to try to put together engine tactile feedback but not using sound card? Keep up the sicknuts work!
    154,711Coins
    +11,210 / 57 / -2
    Best to start your own thread when asking unrelated questions such as transducer support, which by the way will be introduced in the next version of SimTools, which has just entered Beta testing.
  6. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
    Sorry about that! I'll shall do so:) look forward to seeing Beta:)
  7. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
    Just installed pcars plugin and gave it a 30 minute blast and BAM! Works perfectly! Thank you very much value1. Another great job:)
  8. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
    Actually
    Noorbeast sorry about confusin but I was actually asking about the dash output in value1 pcars plugin, not a random question about any old rpm output.
    154,711Coins
    +11,210 / 57 / -2
    The Pcars plugin description is pretty clear - Additional values for instruments are feasible, yet not implemented: http://www.xsimulator.net/community/marketplace/project-cars-plugin.34/
  10. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
    I was wondering if someone had had a play with so called feasibility ;) but cheers for your input bro.
    154,711Coins
    +11,210 / 57 / -2
  12. piorck
    piorck Member
    french
    258Coins
    my pcars game is in version : 9.0.0.0.1174 see in when my game run at on bottom left .
  13. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
    Piorck I'm not to sure what the issue is as I'm actually running and early patch of pcars, I don't have a decent internet connection so it's a bit old. You have enabled shared memory in pcars games settings?
  14. piorck
    piorck Member
    french
    258Coins
    yes i have enable the mms in the pcars game
  15. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
    I thought you would have done. Not too sure what it could be? I'd probably uninstall all apps and just do a reinstall to make sure but fingers crossed for you! There's nothing worse than not being able to cut some laps on sim without it working properly.
  16. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    I had this message when I enabled shared memory and then restarted pCars without rebooting the computer. Did a reboot fix the problem for you?
  17. piorck
    piorck Member
    french
    258Coins
    reboot can't resolve my problem
    i'll run pcars without my T1000
  18. vthinsel
    FRANCE
    6,059Coins
    Arduino, 4DOF
    Maybe a solution you can have a look here
    Cheers, and good luck
  19. piorck
    piorck Member
    french
    258Coins
    my pcars plugin runing !!!!
    just the same message go on but the T1000 move on too .
  20. vthinsel
    FRANCE
    6,059Coins
    Arduino, 4DOF
    What did you do to get it running ? Are you using the shared-memory or the UDP ?
