Project Cars UDP Alternate Plugin
Discussion in 'SimTools Plugins' started by vthinsel, Feb 16, 2016.
  1. Octavio Olvera
    Octavio Olvera G4m3r43ver
    Trade Marketing
    Veracruz. Mexico
    65Coins
    Hi, i´ve tried everything possible but my slider doesn´t move, maybe i´m doing something wrong but i really don´t know what it is.
    1. I installed sim tools and all the components
    2. I downloaded the project cars udp plugin and updated it in sim tools.
    3. I created an empty .txt file in a folder located on my desktop and patched it
    4. I loaded the plugin in the game manager, game engine, game dash and tuning center and also press the capture max/min
    5. I opened the udp .exe file (it receives inmediatly the signal)
    In theory everything seems right but still no signal, I also tried to reinstall and reboot everything several times and nothing works, any ideas? I´m using windows 10 in my laptop and the game runs in xbox one. (sorry for my english)
  2. Octavio Olvera
    Trade Marketing
    Veracruz. Mexico
    65Coins
    I finally made it. I don´t knnow if somebody already commented about it, but it´s important to setup the interface setings and axis assignments, in windows 10 my PC dind´t recognize any ComPort so I had to download a virtual ComPort software and that was the key.
  3. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @Octavio Olvera . what software did you use? im struggling with comports on my windows 8 PC since i factory reset and reinstalled windows.
  4. Octavio Olvera
    Trade Marketing
    Veracruz. Mexico
    65Coins
  5. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
  6. loicdenize
    loicdenize New Member
    mons
    144Coins
    Bonjours , j ai un soucis le pluging fonctionne avec game engine mais quand je lance game dash et lance le bloc note celui ci ce plante et j ai un message ce programme a cesser de fonctionner
    Je suis sous win 10 64 bit
    Avez vous une solution?
    Google translate
    Hello , I have a concern with the pluging working game engine but when I run game dash and launches the notepad this one this plant and I have a message the program to stop working
    I am under win October 64 bit
    Do you have a solution
  7. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,058Coins
    Arduino, 4DOF
    Yes, this is the first thing to do, as detailed in the XSim documentation package. Without proper interface/axis nothing will work. This can be annoying if you just want GameDash to work, but as far as today there is no other workaround.
  8. loicdenize
    mons
    144Coins
    bonjours, game dash est bien lier a un port com car fonctionne avec d autre patch . C'es avec le patch udp qu il plante
    hellos, game dash is linked to a com port as works with another patch. What are the udp patch that he plants
  9. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    333Coins
    Since i'm having issues with the normal pcars plug-in @SilentChill recommend me to give this plug-in a try.
    I have installed the plug-in and the data is received according to VB_UDP_Receiver.exe but nothing is displayed in gamedash.
    I'm pretty sure i have the dash settings correct in game manager
    UPD in game is set at 2
    Am i missing something ?
  10. HoiHman
    Mechanic
    The Netherlands
    333Coins
  11. vthinsel
    FRANCE
    6,058Coins
    Arduino, 4DOF
    Be careful, you shouldn't launch both VB_UDP_Receiver and XSim. Only one process can open the UDP port at the same time.
  12. HoiHman
    Mechanic
    The Netherlands
    333Coins
    Thanks,
    At first i tried using Xsim and simdash only, when that didn't work i used the VB_UDP_Receiver to check the connection to the game.
    Just game it another try, but simdash is not working at all with the plug in. Anything else i could try.
  13. vthinsel
    FRANCE
    6,058Coins
    Arduino, 4DOF
    Have you setup GameEngine fully, including axis assignments and interface settings ? Even if you need only GameDash, you have to configure those. You should see axes moving in output testing.
  14. HoiHman
    Mechanic
    The Netherlands
    333Coins
    Thanks @vthinsel
    No i didnt assign any axis or interface settings. Without it though, game dash does work in Iracing and AC. I will try this and report back, really gratefull you are helping me out.
    What interface settings do i need to setup in game engine, when using gamedash only?
  15. Enrique.Rolon
    Enrique.Rolon New Member
    Argentina
    73Coins
    I did all the following steps:
    1. Install the plugin in a directory path with an empty file called PCARSUDP.txt (directory not in pCars)
    2. Launch Game Manager and select the UDP plugin
    3. Launch pCars game
    4. Open notepad.exe
    But when i look the GameManager the selected plugin swich to pCars plugin (the regular one, not UDP)
    Why this happen? Any ideas?
  16. vthinsel
    FRANCE
    6,058Coins
    Arduino, 4DOF
    Both can't co-exist. Unpatch the legacy one, then delete it.
  17. Enrique.Rolon
    Argentina
    73Coins
    Ok thanks, now it works.
    I installed this plaugin to get the RPM ouput in Arduino Uno and flash some red, yellow and green leds. Do you have the connection code for aduino for the UDP comunication protocol?
    Thank you in advance
  18. razzta02
    razzta02 New Member
    Sales
    Spain, Canary Islands
    378Coins
    4DOF
    Hi, I am planning (or at least trying to plan) my future 3dof with traction loss. Luckily I ended reading today this Simtools-Plugin-ProjectCarsUDP post.
    Really a plugin that will let me keep on playing with my colleagues on PS4? Great idea! Now I just need to start building my sim :)
    Just curious ... does the same exist for Assetto Corsa (PS4)?
    Rgds.
  19. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    No AC UDP plugin as yet, just Pcars at this stage.
  20. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    can i use SMC3 2dof with this UDP plugin from PS4 ?
