Showroom Prototype 6dof
Discussion in 'DIY Motion Simulator Projects' started by NjMotion, Jan 13, 2014.
  1. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    Hi, I am planned to build 6 DOF simulator also, now I'm looking for motor. after I read all the FAQs I still don't know how strong motor should I buy.
    you mentioned your motor are 12 V 50W, how much torque can the motor provide?
    have you tested the maximum weight your simulator can support?
    your information will be very helpful for me, thanks in advance.
  2. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hi Mike.
    My engines are very small for a 6DOF, with 3.5 cm rod motore move well 100kg but as I said many times, it is only a prototype, for a final 6DOF makes better engines, and better electronics.
  3. sonjungin
    sonjungin New Member
    korea ulsan
    122Coins
    very good !!!!! umm it is so cheap and very good
  4. ericRacer
    ericRacer You get old because you stop playing ! Gold Contributor
    Pilot
    Canada, Quebec
    922Coins
    @NjMotion congratulations for your work ! i am thinking i should upgrade my 2dof for 6dof .....soon.
    keep your good work.
  5. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Thank you!!! :cheers
    I am glad that this project opened the doors to as many people as there are now with its 6dof under construction. :thumbs
  6. Coop
    Coop New Member
    England
    147Coins
    Any progress with the 6dof prototype? @NjMotion
    I have been looking at your SV2 and SV3 but would be really interested, as would a lot of other people, if you manage to bring this low cost 6dof to a finished product.
    I've got a few questions about the other models you build but will ask them in the relevant threads.
    Great work you are doing!
    Coop
  7. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hi @Coop
    I would like very much to start with the 6dof and see where we can get with it but now I do not have time, I'm very late with the models I already have and I do not know when I can start the ones I have pending.
    Thank you for your comments :thumbs
  8. Coop
    Coop New Member
    England
    147Coins
    Well that's fair enough mate, it is almost certainly a sign of your good work that you are so busy @NjMotion
    I look forward to any progress you make and am keeping an eye on your other builds while I make my mind up regarding my own rig, which I intend to start very soon.
    You and many others here are inspiring a lot of impressive simulator builds. :thumbs
  9. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    hey
    hey! did you finish your project?
  10. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    The truth is that the 6dof I have not started yet and I do not know when I will do it.
  11. Mpmo
    Mpmo Member
    1,289Coins
    ahh i see
  12. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    Please start your own thread rather than use other member's thread: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    You will find the FAQs cover most common questions: https://www.xsimulator.net/community/faq/
  13. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hi @andre747
    If you start your project safely you will do it in a new thread.
    You connect an arduino to two motors and the same thing twice more.
  14. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    I'll be there in case I can help you :thumbs
  15. robKen
    robKen New Member Gold Contributor
    China
    107Coins
    2DOF, AC motor, Arduino
    Excellent job!
  16. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    love the low cost test!
  17. BM114
    BM114 New Member
    236Coins
    Absolutely. In fact most of the industrial servos I've seen use AC. I would like to add that using brushed or bldc motors are likely to output more power per volume compared to AC induction motors.
    @NjMotion
    After seeing this work. I finally pulled the trigger myself and ordered a worm gear motor from Ebay to test. It's supposed to output 18rpm and I'm hoping it is true to the claims made on force supplied.
    https://www.ebay.com/itm/300W-DC24V...elf-locking-/202688119289?txnId=1808267324010
    I selected an appropriate motor driver from robotshop.com that should control speed/direction for the brushed motor.
    Thanks for sharing your process with your prototype. It's a big help for those of us looking at a budget tight build.
  18. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Thanks @BM114
    Good luck with your project, I will follow it if you publish it.
  19. Razvan
    Razvan Member
    Programmer
    Israel
    311Coins
    Arduino, 6DOF
    Hi Nj. could you please share (or link) the arduino code for the MMs for your 6dof?
    Tnx,
    Razvan.
  20. noorbeast
    154,699Coins
    +11,210 / 57 / -2
