Questions - Help - 3DOF AC Platform IT Begins -
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by cthiggin, Feb 16, 2014.
  1. BlazinH
    16,670Coins
    I did a little reading to test myself and I did find that...
    And I found a more technical answer than saying magnetism repels the electricity...
    And a better explanation on the effects of grounding it...
    • Informative Informative x 3
  2. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    BlazinH,
    GOOD stuff...
    Will put 14-3 w/g and foiling INSIDE flex conduit. Will put shielded pot cable on outside of flex conduit, zip tie........
    To me, maybe overkill, but should not have to explore that component of the build as a problem area.......
    Of course, the 14-3 will be earth grounded - will NOT ground the pot cable.
    Thanks to you and all,
    Tom
  3. telfel
    telfel Active Member
    4,738Coins
    Hi
    you can use CY flexible cable, comes in various size's and number of cores, you still need an earth core as well as the screen. Then you can zip tie your CAT6 cable to the CY.
    I do not think home made screening earthing / methods are suitable for HV wiring,
    If your are not familiar with HV wiring methods and practice I would recommend you get an electrician to check it out.
    Mains voltage especially at high frequencies is a killer.
    regards Terry
  4. SeatTime
    Also don't mix up a signal ground and a electrical ground/earth. Be aware also of signal earth loops.
  5. BlazinH
    16,670Coins
    I like the idea of zipping your pots cable to the outside of your flex cable. For home security systems, experts recommend keeping its cable a distance of at least 2 inches from household wiring to avoid problems. But they said short runs are less likely to cause interference. So, the bottom line is you will just have to try it! If your pots do give erroneous results, it will be easy to cut the zip ties and reroute them with them being on the outside.
    Also, heed SeatTime's warning!
  6. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hello Gentlemen,
    THANKS so much for your advice and wealth of information.
    I now have a workable "game plan" and will proceed forward.....
    With your information, hopefully I can do this ONE TIME and not have to be worried with interference.
    I have, will, do understand and heed your warnings.
    Have a blessed one,
    Tom
  7. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    inside my motors , i have no wire brush touching the inside side of the motor. i haven't cut and soldered because i haven't been able to figure out which is the earth ground wire. but what if i were to run a ground wire from the casing on the motor to the ground of the terminal thats on the power supply unit and ground it that way? anyone try that?
